Exterior Slopped Soffit Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 12:20 AM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
exterior slopped soffit lighting
Hello,
Has anyone installed recessed lighting in a sloped soffit?. I want to add 2 lights in my gable end but normal cans will shine down on a 45 degree. I want them to shine straight down. Any ideas on slopped cans?
ryanh is offline   Reply With Quote
Old 05-28-2009, 04:47 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by ryanh View Post
........Any ideas on slopped cans?
Halo has #76 Adjustable Gimbal Trim that will adjust up to 50. NOT rated for Gabels though, best bet would be low voltage
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-28-2009, 06:33 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Hello,
The make an "eyeball" trim kit so you can adjust the light direction.
rjniles is offline   Reply With Quote
Old 05-28-2009, 10:59 AM   #4
Rewards Points: 160
You may not have enough space/clearance above the fixture. This could be a problem. If you find one that fits, make sure you can meet the clearance described in the fixture literature.
This also may be considered a wet location. Should this be the case, you would need special weather tight fixtures.
Old 05-28-2009, 09:35 PM   #5
ryanh's Avatar
Rewards Points: 154
Thanks for the replys guys. Ya eyeball trim won't look good for downlight since it can't be placed deep in the can. All i could find was some sloped cans by halo but require 7 1/2" clearance, I got 2x6 Fascia so i'm looking at 5.5"
Found some 4" Low Voltage that require 5 5/8" which will be fine, but then i already got 6 other 4" Line voltage cans for the rest of the soffits. Pretty pricey to switch to all Low Voltage but i might have no choice ..
Outdoor Soffit Lighting joedadog Electrical 18 03-07-2012 04:18 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
