-   -   exterior slopped soffit lighting (http://www.diychatroom.com/f18/exterior-slopped-soffit-lighting-45430/)
ryanh 05-28-2009 01:20 AM
Hello,
Has anyone installed recessed lighting in a sloped soffit?. I want to add 2 lights in my gable end but normal cans will shine down on a 45 degree. I want them to shine straight down. Any ideas on slopped cans?
PaliBob 05-28-2009 05:47 AM
1 Attachment(s)
Originally Posted by ryanh (Post 279581)
........Any ideas on slopped cans?
Halo has #76 Adjustable Gimbal Trim that will adjust up to 50°. NOT rated for Gabels though, best bet would be low voltage
rjniles 05-28-2009 07:33 AM
Hello,
The make an "eyeball" trim kit so you can adjust the light direction.
J. V. 05-28-2009 11:59 AM
You may not have enough space/clearance above the fixture. This could be a problem. If you find one that fits, make sure you can meet the clearance described in the fixture literature.
This also may be considered a wet location. Should this be the case, you would need special weather tight fixtures.
ryanh 05-28-2009 10:35 PM
Thanks for the replys guys. Ya eyeball trim won't look good for downlight since it can't be placed deep in the can. All i could find was some sloped cans by halo but require 7 1/2" clearance, I got 2x6 Fascia so i'm looking at 5.5"
Found some 4" Low Voltage that require 5 5/8" which will be fine, but then i already got 6 other 4" Line voltage cans for the rest of the soffits. Pretty pricey to switch to all Low Voltage but i might have no choice ..
