Exterior Porch Light And Load - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 05:20 PM   #1
Exterior Porch light and load
Hello all,
I am wiring an addition (8 recessed, 1 fan/light). I want to add a switch by the door for an exterior porch light. Should be no problem with that, right? No need for GFI since there will be no switch outside, right?
Also, I'm getting conflicting answers from a local electrician and what I am understanding to be correct. When loading a 15A light circuit, shouldn't you take the fixture's max rating when calculating the load to prevent future idiots from tripping the breaker? The electrician is back-pedaling now on the advice he gave me a while back by saying I could have combined rooms. Combining those rooms would put the total load way over 15 A if everything was on (based on max). I realize CFs are going to change the game but max fixture rating rules the day, right?
Thanks!
gmyers is offline   Reply With Quote
Old 03-22-2012, 05:37 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You probably could tie those loads onto an existing circuit or add the recepts in the room and have that whole room on 1 circuit, but if you are doing an addition, I would have a circuit for the new lighting and a separate new circuit for the recepts in that room. Its not that much extra and you wouldn't be "pushing" anything.
Old 03-22-2012, 07:24 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Lighting is always figured at the max wattage of each fixture when calculating the circuit.
jbfan is online now   Reply With Quote
Old 03-23-2012, 08:48 AM   #4
Thanks for the sanity check!
What about the GFI I for the outside light? Not needed, right?
Thanks!
Old 03-23-2012, 09:14 AM   #5
k_buz's Avatar
Thanks!
Not needed
Tags
load , porch light
Wiring issue on light wkuengineer Electrical 9 06-03-2012 02:08 PM
Switch Before Load or After - does it matter? Tryvidy Electrical 16 03-04-2011 09:47 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 11:02 AM
3 way switches with light load on both ends boutwater Electrical 2 03-07-2010 12:05 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
