Exterior Lights Flashing - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 09:47 PM   #1
WTB
Exterior lights flashing
Today I replaced two exterior lights with new, energy star lights. The new lights use CFL bulbs, and both utilize photocells. My plan is to leave the interior switch in the on position, and let the photocells determine when the lights need to turn on. Everything appeared okay tonight, at least initially. As it became dark, the lights turned on. However, after a couple of minutes, they both began to flash on and off. I turned the interior switch off, thinking maybe it wasn't quite dark enough for them to stay on. It's now pitch black outside, and the lights are exhibiting the same behavior. Any ideas on what might be going on would be appreciated. Thanks in advance.
WTB is offline   Reply With Quote
Old 06-02-2012, 09:54 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The photocells could be seeing the light given off by the fixture. How quickly do they flash?
The Following User Says Thank You to k_buz For This Useful Post:
Yoyizit (06-02-2012)
Old 06-02-2012, 09:57 PM   #3
WTB
The lights are on for about 45 seconds before they start to flash. The flash itself is very quick, the light is off probably about 1 second.
Old 06-02-2012, 09:58 PM   #4
If it is a very faint flash it could be due to a small amount of power trickle. Sometimes a switch can still allow a small amount of electricy past and cause a faint flash with cfl bulbs. Switch them to an older incandesant and see it is still happens. The incandesent needs more power to light up than a cfl, so it will not exhibit the problem. If the incandesant is working normally, it is most likely the switch or photo eye allowing a small amount of power through.
HandyAndyRR is offline   Reply With Quote
Old 06-02-2012, 10:01 PM   #5
WTB
Not exactly sure how to define a faint flash, but in this case the bulb goes completely out, then comes completely back on again. I don't think I can swap an incandescent, as the fixture only takes the two-pin lights (unless I can get those in incandescent?)
Old 06-02-2012, 10:03 PM   #6
k_buz's Avatar
Are the photocells built into the fixtures? Did the light bulbs come included with the fixtures?
Old 06-02-2012, 10:04 PM   #7
WTB
buz, Yes to both questions.
Old 06-02-2012, 10:05 PM   #8
k_buz's Avatar
Could it be that there is a motion sensor on these fixtures as well?
Old 06-02-2012, 10:09 PM   #9
WTB
I don't think that's the case. Just looked at the manufacturer's web site, and there is no mention of it.
Old 06-02-2012, 10:10 PM   #10
If it is coming on fully than it does not sound like what i was describing, i have only ever seen that as a very faint flash. I would think that the eye is positioned so that the light from the bulb is turing it off and then gets dark and comes back on.
Old 06-02-2012, 10:13 PM   #11
k_buz's Avatar
If it doesn't have a motion sensor (you can post the make and model and we can take a peek) another guess would be to make sure the bulbs are inserted properly/completely.
Old 06-02-2012, 10:17 PM   #12
WTB
@Andy - That definitely seems to be what is happening, but I'm hoping it's not the case as that would probably be a negative statement on the design of the fixture :-)
@buz - Manufacturer is Hinkley. Fixtures (both) are Trafalgar, model 1314MB-EST. I'll go check the seating of the light bulbs...
Old 06-02-2012, 10:22 PM   #13
k_buz's Avatar
I am looking at the fixture and they don't appear to have been manufactured with the photocell as I was assuming. Did you install the photocell? If so, where did you install it that it could not see the light from the bulb?
Old 06-02-2012, 10:43 PM   #14
WTB
The manufacturer installs the photocell when the energy star "version" of a fixture is ordered. It's installed at the bottom of the backplate.
It must be that the photocell is being impacted by the light from the fixture. The two lights I installed are both flashing, but at different intervals.
Old 06-03-2012, 01:12 AM   #15
" Euro " electrician
frenchelectrican's Avatar
If you did see the photocell how many conductors that goes to the photocell ?? there should be either 2 or 3 conductor verison let us know which one you have.
If you have 2 conductor verison that useally cause the issue with CFL due the photocell set up they don't work very well with electronique loads but standard load like indentscent bulb it will work just fine without flicker.
So that why I rather use the three conductor verison if possble. The reason why is due the three conductor verison the CFL electronique loads will not affect it due the netural will be at the photocell to use the power to engerized or deengerized the load.
( the three conductor verison will have black{ line }, red { load } , white {netural } conductors )
Merci,
Marc
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 12:53 PM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 05-01-2012 12:42 AM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 09:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 01:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
