Exterior Lighting Outlet: Round Or Rectangular Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 08:20 AM   #1
exterior lighting outlet: round or rectangular box?
new construction application, looking to add exterior sconce lighting on wood siding, utilizing a wood mounting block. face of box would be flush with mounting block, with exterior light mounted over it (i.e. the box would not be outside). so my question is should i use a round or rectangular box (2x4)? most of the stuff i am finding online uses round boxes but is there really an issue with using rectangular? it appears as if some light fixtures require round boxes, due to the shape/size of the portion of the fixture that would be flush with the mounting block so it would seem using a rectangular box may limit my choices of available fixtures but if the fixture entirely covers the box, what's the difference? reason i ask is i don't have a hole saw and would rather not spend $20 on one to make one hole or fool around with trying to make a round hole without one. i suppose i could use a jig saw.
what do other folks mostly see out there, round or rectangular boxes?
itsnotrequired is offline   Reply With Quote
Old 10-25-2013, 08:27 AM   #2
Master Electrician
Rewards Points: 3,822
It is usually far easier to mount a fixture on a round or octagonal box.
brric is offline   Reply With Quote
Old 10-25-2013, 08:30 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
In my limited experience its always been round or octagon. I hypothesize that the diagonal orientation of the screw holes provide better up down left right stability to the installed fixture. Most likely that is a load of feces but I can't turn off my mind even when it is heading over the cliff.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-25-2013, 08:35 AM   #4
this was the conclusion i was coming to, based on my limited internet research. i should be able to cut a halfway decent hole using my jig saw.
thanks!
Old 10-25-2013, 08:36 AM   #5
Licensed electrician
Rewards Points: 1,494
A rectangular box can only support small fixtures. The round box gives you more options.
Old 10-25-2013, 12:05 PM   #6
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Depending on the base of the light a "pancake" box may work ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 10-25-2013, 12:22 PM   #7
i thought about that but since the siding isn't even up yet, simple enough to use a full size box and not have to screw around with wire fill, etc.
Old 10-25-2013, 12:47 PM   #8
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
So much easier to make a round hole with a hole saw than to make a square hole.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 10-25-2013, 12:49 PM   #9
agreed...but i don't have one of those and don't want to buy one to make one hole.
Old 10-25-2013, 06:37 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Every application is different... I favor no option over the other, I go with what I'm delt with.... par for the course...
Old 10-25-2013, 07:15 PM   #11
Bill Kearney
Rewards Points: 1,174
Or use a siding mounting block instead. Then you'd just be applying the siding up to the edges of it. Can't recall the brand, but there's at least one kind that's made of the same stuff as cement shingles. Sturdi-mount? That and Arlington and Special-Lite make others.
wkearney99 is offline   Reply With Quote
Old 10-26-2013, 01:15 AM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Will a light fixture even fit in a rectangle box? I don't think the screws even align the same way.
Old 10-27-2013, 07:12 AM   #13
Bill Kearney
Having just mounted a dozen different kinds of lighting both inside and out, all of them came with brackets necessary to mount on several kinds of boxes: regular outlet, 4" square and 4" round. But it'd certainly be something to check on before purchasing, or just pick up the brackets at a lighting place.
Old 10-27-2013, 12:17 PM   #14
Sparky
Rewards Points: 510
if you use a rectangular 'device' box, you'll be limited to a 6lb total weight for the fixture. 314.27 (a)(1).
Techy is offline   Reply With Quote
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
