Exterior Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 03:56 PM   #1
Exterior Lighting
I pulled down my old exterior home lights and put a multimeter on them, I find I have 30 volts AC. I was expecting either no voltage or around 120. I do not appear to have any switches for the lights, they did come with motion detector initially. why do I have 30 volts?
david.pfeifer73 is offline   Reply With Quote
Old 09-26-2010, 04:02 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
could be what many call "phantom" or "ghost" voltage.
It is the result of induced voltage and while real, it does not have enough current to be of concern.
that is one of the problems with digital meters.
of course, there are always other possibilities but the phantom voltage is the most likely.
if you have a very low wattage lamp (bulb) you could put in circuit, it would help diagnose. If it does not light or the voltage actually disappears, then it is simply phantom voltage.
