Exterior Light And Outlet Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 12:06 PM   #1
Rewards Points: 24
Exterior light and outlet installation
Hi there,
The way my builder has installed an exterior light and outlet seems to me wrong because it allows water to penetrate beneath the siding. I would appreciate if someone look over the attached pictures and confirm or deny my concerns. The advice how to correct the problem if it does exist would be great as well.
Thanks.
Exterior light and outlet installation-ext_light1.jpg   Exterior light and outlet installation-ext_outlet.jpg
barmaley is offline   Reply With Quote
Old 12-17-2011, 12:32 PM   #2
Julius793's Avatar
I wouldn't be that concerned but if it bothers you just put silicone where ever there's a crack
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-17-2011, 01:12 PM   #3
Rewards Points: 24
Thanks. I thought about caulking but the gaps are too wide ~1/2" for it.
Old 12-17-2011, 01:26 PM   #4
Facilities Maintenance
Use foam insulation, wipe it smooth with a putty knife, paint it to the color of your home. Good to go.
Or you can use an exterior plaster or porcelain.
The installation is correct, it's just how your siding is, and the design/shape of the light. DOing the above will work.
Just make sure your exterior electrical recepticle (plug in) is GFCI per NEC 210.8
BigGuy01 is offline   Reply With Quote
The Following User Says Thank You to BigGuy01 For This Useful Post:
barmaley (12-17-2011)
Old 12-17-2011, 02:26 PM   #5
Rewards Points: 89
I have no experience in this area, but if it were my house I'd be concerned too. Logically, it seems like water will certainly run down the siding above the fixture, hit the block, and be channeled right down inside the siding to either side. I can't believe this is how it's supposed to work, but if so and the builder won't fix I would definitely foam+caulk it as the others have described.
Matt
gatorheel is offline   Reply With Quote
Old 12-17-2011, 02:40 PM   #6
Rewards Points: 24
Thank you all! I'll try to foam it.
Old 12-17-2011, 05:59 PM   #7
Limited Experience
THEN put caulk over the foam.
I have not seen any of the expanding foams that are weather rated.
raleighthings is offline   Reply With Quote
Old 12-17-2011, 06:15 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
That IS how it is supposed to work.
That is a typical siding block. The perimeter of that block is the SAME thing as every window, door or other opening's j-channel.
You need not be concerned about this at all.
Old 12-18-2011, 08:35 AM   #9
Rewards Points: 24
Could you please explain how such way of installation can prevent water from coming behind the siding? There are 1/2" gaps between siding and siding block and no any J-channels.
Thanks.
Old 12-18-2011, 08:52 AM   #10
Licensed electrician
Rewards Points: 1,788
The J channel is built into that box. There is a flange that extends out past the siding cuts. It is shown covered by the black tar paper in the one shot.
Old 12-18-2011, 09:05 AM   #11
Rewards Points: 24
Thanks. So you agree with Speedy Petey that everything is fine and I shouldn't worry about this, right?
Old 12-18-2011, 09:41 PM   #12
Yup, what Jim said. The flanges underneath are at least as wide as the outer flanges. Some water can probably get behind there, but this is why there is tar paper or tyvek back there.
Old 12-19-2011, 03:54 AM   #13
Rewards Points: 1,192
I would goober it up with duct seal,then silicone.Paint to match.
bobelectric is offline   Reply With Quote
Old 12-19-2011, 06:51 AM   #14
If you decide to fill the gap, the suggestion above should work fine. When I replaced my patio doors with French doors, there were gaps of 1/2" or so in some places between the trim and stucco wall. I filled the gap with foam, covered it with a layer of paintable caulk and then painted to match the wall color. This has worked fine for at least five years now.
David
Jessidog is offline   Reply With Quote
Old 12-19-2011, 07:48 PM   #15
Rewards Points: 24
Thank you all guys!
Help with new outlet installation ajm Electrical 9 11-07-2011 07:12 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Rear outlet toilet installation help RICK430 Plumbing 7 09-13-2011 11:07 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
