Exterior Light Fixture Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 11:39 PM   #1
Exterior light fixture installation
I will be installing a few exterior lights on my garage and I'm not sure how they typically install. Do I need to install boxes on the inside of the garage or does the fixture act as a box??? It is your standard vinyl siding on the outside so I know there has to be some sort of J-box or J-channel to work with the vinyl. Is there any type of fixtures to avoid???
Thanks!
MisterSteve is offline   Reply With Quote
Old 03-18-2012, 12:55 AM   #2
You'll want to get a light mounting kit. They make them specifically for siding installation, with j-box included.
Check out Arlington Enterprises.
jammin06 is offline   Reply With Quote
Old 03-18-2012, 07:12 AM   #3
Rewards Points: 2,516
What do you mean by standard?
Traditional Double 4"
Traditional Double 4.5"
Traditional Double 5"
Triple 3"
Dutchlap Double 4"
Dutchlap Double 4.5"
Dutchlap Double 5"
And many more........
There are mounting blocks that get installed by taking the siding off, cutting the siding, installing the mounting block then re-installing the siding.
There are mounting blocks that can be installed directly over the existing siding but for this you need to know what type of siding you have. Standard would not be a choice.
Exterior light fixture installation-gerger.jpg   Exterior light fixture installation-gerger2.jpg   Exterior light fixture installation-mounting-block-mid-am-1.jpg   Exterior light fixture installation-faucet.jpg
hammerlane is offline   Reply With Quote
Old 03-18-2012, 07:35 AM   #4
It's 5" double lap. I know the siding has to be removed and cut to fit around the j-box, but my main question is, when running all my wiring should I go ahead and mount a light fixture wiring box on the inside of the wall or will the fixture itself act as the wire box? I'm guessing I should choose a fixture before doing anything???
Old 03-18-2012, 08:09 AM   #5
Arlington mounting box 8141-1 has an integrated box. WIth this you only drill a hole in siding to feed your wire.
Or if the inside of your garage is unfinished you could do the following:
http://www.youtube.com/watch?v=4Y5Z3...eature=related
Light Fixture Installation, 3 wires and none are hot PugDadda Electrical 9 01-03-2012 12:45 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 07:40 PM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 06:13 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Installed Fixture, Unexpected Result bigphaty Electrical 1 06-17-2008 12:25 PM
