Exterior Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 10:51 PM   #1
Rewards Points: 77
Exterior Light
When intstalling a new outside light, what needs to be present on the exterior. Once I bring the wire down from the exterior wall and out to the outside what sort of box do I use? Does there need to a flush mounted box with the exterior sheathing or can I go right through and mount a box on top of the siding. I am looking to install a lamp style exterior light (not motion sensor) and I am confused by the from the transition from exterior wall to actual light and what I need to do for boxes etc. (round, square) and so forth. Thanks again
gregt848 is offline   Reply With Quote
Old 03-12-2010, 11:02 PM   #2
Licensed electrician
Rewards Points: 1,266
I like to use these.
http://www.arlcatalog.com/Siding/Sid...its%20GFCI.htm
Old 03-13-2010, 02:50 AM   #3
Electrical Contractor
kbsparky's Avatar
Or these.
-KB
