#1 |
Exterior GFI will not reset
You'll have to excuse the ignorance of a first time homeowner ... I am needing some guidance on an Exterior outlet I am having problems with. Here's the background info ... my home was built about a year and a half ago. I just moved in and the inspector noted that none of the exterior outlets (there are three total) are working and the GFI on one of them will not reset.
My first instinct is to install a new GFI outlet in place of the one that won't reset, but I'm not sure if I'm over-simplifying things. Let me know if I'm headed in the right direction or any other pointers you can give me ... Thanks! Megan
#2 |
Electrical Contractor
Call the builder and let him fix it. If you touch it, he may try to back out of any warranty
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Unfortunately, the house is no longer under warranty with the builder. It was under a one year warranty, which expired before I purchased the home.
#4 |
Another DIY Zombie
Check the main panel and see if that breaker is also tripped.
#5 |
Moderator
GFCI devices aren't exactly military grade hardware, and they go bad on a regular basis. As an inspector, I bet 1 in 75 brand new GFCI's that I test on new construction won't reset. They replace the device with a new one and everything is fine (in most cases).
Check your breaker first and see if it is on. If it still doesn't reset, kill the breaker and replace the GFCI. There could be something else wrong, but the aforementioned things are the best that most DIYers can handle. |
#6 |
Another DIY Zombie
I had a bad one, right out of the box about a month ago. You are correct it happens!
#7 |
Verify power at the recep.
If GFI is being used line-load, remove load. Try to reset. If it resets, have load wiring checked. If it doesn't, replace GFI. If no load wiring simply replace GFI. |
#8 |
Idiot Emeritus
GFI's have line and load terminals. Line in incoming power, load is outgoing. It's quite common to have these reversed on the original installation. Most GFIs won't reset if the incoming power is on the load terminals. If it's never worked, this would be a good place to start.
This is more rare, but some GFIs won't reset if the hot wire is on the silver screw (which in supposed to be neutral). Just because a white wire is on the silver screw doesn't absolutely mean it isn't hot. It could be mis-spliced somewhere upstream. Rob P.S. The above posts are exactly correct. Last edited by micromind; 07-01-2008 at 10:33 PM. Reason: Added P.S. |
#9 | |
When is fishing season?
Exterior GFI will not resetQuote:
BTW, we are neighbors! I am right down the road from you in Chateaugay... Also, when you check the breaker to see if it is tripped, move it all the way OFF first, when they trip sometimes they don't look like they did...
I DON'T OWN MY HOUSE... MY HOUSE OWNS ME!
#10 |
Thanks for all the info guys ... I checked the breaker in the garage and it is not tripped. I'll pull the outlet out this weekend and try troubleshooting the wiring and maybe just go ahead and replace the GFI. I'll keep you posted ... hopefully I can get this stupid thing working!
Thanks again ... happy 4th! Megan
#11 |
Well, we pulled out the electrical outlet last night and found the problem. Water had gotten behind the outlet and the screws and everything were rusted, so I'm sure the water shorted the GFI. We connected the wires to create a pass through and the other exterior outlets had power. So we're off to Lowes tonight to get a new GFI outlet WITH plastic cover
![]() Thanks for all the tips!!
#12 |
typically a GFCI will not reset and trip using the buttons on the front if power is not available at the device. The one of three that won't reset if on the same circuit is probably not working or wired properly. It is unusual for multiple GFCI's to be on the same circuit, usually they are daisy chained by using the line/load connections on the device itself, normally the first device is the only GFCI device on the branch circuit. Normally exterior and bath circuits are on their own, but in kitchens their is typically 2-20 amp small appliance circuits that sometimes have regular receptacles that are gfci protected.
Check the panel breakers first, if the device will reset and trip it is probably ok. If you don't have a meter or test light try a lamp to find out if you have juice, try tripping it while it is plugged in. If the inspector is worth his salt he should be able to tell you what the problem is. |
#13 |
Master Electrician
That is not the job of an inspector.
John from Baltimore One Day at a Time To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Experience is what you get when you were expecting something else" "The bitterness of low quality lingers long after the sweetness of low cost is forgotten" |
| Tags |
exterior, gfi, reset ![]() |
| Display Modes | |
| Security System: Pass Code Reset | Dave in Michigan | General Discussion | 4 | 12-01-2007 09:30 AM |
| Oil burner won't kick on, have to push reset | edski | HVAC | 4 | 11-06-2007 03:04 PM |
| GFI wont reset | john49 | General Discussion | 2 | 09-21-2007 09:33 AM |
| My GFI sparked and won't reset | pgallardo | Electrical | 6 | 10-17-2006 01:42 PM |
| GFCI wouldn't reset, now it will | sherlock | Electrical | 4 | 10-18-2005 11:13 AM |
