Exterior Carriage Lights - Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2006, 01:43 AM   #1
I am building a new garage and would like to put carriage lights on either side of the garage door. At present, the framing is covered with sheathing, but will eventually be finished in stucco.
Can I use a regular octagon box attached to the studs and protruding through the sheathing and stucco? I'm considering a duplex outlet on the outside of the building as well, but I would rather not have to use those weatherproof boxes with EMT and whatnot...Thanks.
tkdcal is offline   Reply With Quote
Old 06-02-2006, 06:14 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro electrican, but yes you can use a regular octagon box for the light fixtures.
The receptacle will have to be GFCI-protected.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-02-2006, 02:49 PM   #3
What weather proof boxes with emt?
jwhite is offline   Reply With Quote
Old 06-02-2006, 07:40 PM   #4
For the recptecle do the same as you mentioned for the lights, except with a single gang box. Only the cover will need to be weatherproof, and with a GFI installed.
Sparky Joe is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
Lights for a garage? stagger19 Electrical 8 01-16-2007 06:58 AM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 11:11 PM
