Old 10-29-2009, 02:32 AM   #1
Send a message via AIM to theatretch85
Default Exterior 50 Amp RV Outlet
I just bought a weatherproof 50 Amp RV outlet enclosure from homedepot.com. I am looking to install this on the front of my house near the front door so that I can plug in a portable sub panel in the winter time for the holiday lights. I bought the enclosure with the thought that I'd route the wire through the siding into the back of the box; however when I got it today I noticed it does not have a knockout on the back. It has one knockout on the bottom with sizes from 1/2" to 1 1/4" and an option for a hub on top. My initial thought is to just drill a knockout for the back, and install the clamp, drill the hole in the wall and attach it. Then run a bead of caulking all around the unit, and that'd be it.
I'd like to make this as simple as possible, and honestly thought about running it in through the bottom of the box via an LB but I am also installing a 20 amp outlet on its own circuit (since there is no standard outlet on the front of the house) but the thought was to run PVC conduit out the bottom of the 50 amp enclosure, along the wall and to the 20 amp outlet. Again this outlet would be on its own circuit, and I would just be using the 50 amp enclosure as a J-Box to convert from Romex to THWN wires for the 20 amp outlet.
I know it technically voids the UL listing to modify the box, but what would be the harm in drilling my own knockout for a 3/4" clamp to mount to the back side of the box so long as I seal it up with caulking?
Anyone have a better option that doesn't require running conduit and THWN wires all the way from the panel? I am of course using 6/3 NM and already had it run ready for the outlet to go in today.
The Outlet enclosure is made by Connecticut Electric Model: PS-54-HR.
theatretch85 is offline   Reply With Quote
Old 10-29-2009, 09:09 AM   #2
T85: There is not an electrician,technician, etc. that has not modified something to do the job at one time or another. I would do the same as you're considering. There will always be an item you'll need that the manufacturers have not offered. The ability to make the unworkable work is the mark of a pro.
oilseal is offline   Reply With Quote
Old 10-30-2009, 12:37 AM   #3
Idiot Emeritus
I can't even think of how many thousands of times I've punched my own knockouts in electrical equipment. Most of my work is inspected, no one has ever questioned it.
If modifying the box violates the UL listing, then about 1/2 of the stuff I've installed in the last 19 years is no longer listed!
Go ahead with your plan, it'll work just fine.
Rob
micromind is offline   Reply With Quote
Old 10-30-2009, 12:57 AM   #4
" Euro " electrician
I am on the same page as Micromind was explaing I done that all the time in Wisconsin and in France sure I know sometime I will void the UL/ CEU listing but ya need something done in legit way like punch my own KO's I done that all the time.
Merci,Marc
Old 10-30-2009, 01:22 AM   #5
Awesome! Just what I was looking to hear! Thanks for all the responses! I'll try and remember to take some pictures to post up here when I am done with the project.
Old 11-03-2009, 02:14 AM   #6
Just got around to mounting and running the wire into the RV outlet box and mounting the box for the low voltage wiring (conduit fed). I have attached the pictures from the inside view, I can hopefully get pictures from the outside tomorrow as it was getting dark outside.
What do people recommend on sealing up around the romex into the RV outlet box? I was thinking caulking around where the metal meets the siding, then filling in the back side around the wire and next to the wood blocks with spray foam.
Also, what is the best way to seal up the metal J-Box with all the holes on the back side? I have some Duct Seal left from when I did my panel swap; would this be the best thing to use or should I just use some caulking to fill the holes in and spray foam the backside?
exterior-50-amp-rv-outlet-11-02-09_2332.jpg   exterior-50-amp-rv-outlet-11-02-09_2333.jpg   exterior-50-amp-rv-outlet-11-02-09_2334.jpg   exterior-50-amp-rv-outlet-11-02-09_2335.jpg   exterior-50-amp-rv-outlet-11-02-09_2336.jpg
Old 11-04-2009, 02:57 PM   #7
Anyone have any reccomendations on sealing up the pentrations around the openings in the wall and the boxes? Wondering if Duct Seal is the best use for sealing up the holes in the back of the metal box or if I should be using caulking? Also, as I stated above, I plan on sealing up the backside with some spray foam around the holes and wire for insulation purposes.
Old 11-04-2009, 03:25 PM   #8
Licensed Pro
Duct seal.
Old 11-04-2009, 11:28 PM   #9
Child Alert! Pull Up!
fltdek's Avatar
Nicely Done!
Ever see one of these?
fltdek is offline   Reply With Quote
Old 11-05-2009, 01:07 AM   #10
Yep, even used them before too. Though I don't need a full greenlee set on a regular basis so I can't justify the cost of the whole set. I just used a 1" hole saw to cut the hole in the back of the 50 amp outlet box, and a 1 1/4" (or maybe 1 1/2") hole saw for the wires to go through the wall and to allow room for the romex clamp.
Should the Duct Seal go on the outside edge (the side you can see in the pictures) or inside the box (facing outside)? I am wondering if maybe wrapping the j-box in the plastic box wrappers (not sure what they are called - they are intended for indoor outlets on outside walls and go inside the wall around the box and seal up to the sheetrock) and then use caulking only along the edges where the plastic meets the backside of the siding (rather than filling all the holes with caulking or duct seal). I'll see if I can find a picture of what I'm talking about.
More On This Topic
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
So this is where we are going to put the new outlet. I have a stud running down along here or you can find your studs with a stud finder. In an older house a lot of times you can see the nail line running down the wall where they nailed the sheet-rock to... Read More »
The majority of televisions in homes today are built around the cathode ray tube. With plasma televisions, the central element is the plasma in a fluorescent light made up of electrically charged ions and electrons that are free flowing and gaseous. The... Read More »
One of the best tools for any do-it-yourself person is an electric drill. It can be used for anything from hanging a picture to making a bookcase. From installing light switches to installing paneling, an electric drill is a simple "must have" for any... Read More »
I'm Carolyn speaking for Expert Village. Then we would also if you would like to have like a small drill and parts to go with it that is handy around the house we have this little set that you can you put this into the drill and then you put one of these... Read More »
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 16 10-24-2009 03:19 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 04:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 11:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 05:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 10:45 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
