Extention Cord Dropped Into Pool - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 09:18 AM   #16
I'm just trying to learn: If the GFCI won't trip when you drop a hair dryer into the tub, then why have GFCI's ?
Bloke is offline   Reply With Quote
Old 06-16-2011, 09:45 AM   #17
I=E/R
a7ecorsair's Avatar
Electricity is used by many but many don't understand it.
For current to flow there has to be a complete path. Birds can sit on a power line and not get shocked because there is no path for current to flow.
A fiberglass bathtub plumbed with plastic pipe is a very poor conductor and therefore doesn't provide a return path for current to follow.
A ground fault receptacle monitors the current in the two straight pins. If it is equal then there isn't a fault. If it is different then current must be flowing through some other path other than the hot and neutral.
By dropping a hair dryer into a bathtub plumbed in plastic there is no "third conductor" and all the current in hot pin can only return through the neutral pin and so there is no fault.
Plastic plumbing has removed many of the ground paths that used to be in a house.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
electures (06-16-2011)
Old 06-16-2011, 09:47 AM   #18
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
In order for the GFI to trip there must be a ground fault. Hence the name Ground Fault Interupter. The device monitors the current leaving and returning to the device. If it is same, then the sensing circuit does nothing, however, if there is less current returning then leaving then that means it is returning to the the source (grounded side of the service) through another means (ground fault). The sensing circuit senses the unbalance and trips the circuit. If a hair dryer is dropped into the tub and there is no path to ground (all plastic) , the GFI will think it is a nomal load and not open. Since water is not a perfect conductor (it offers some rsistance) the breaker will not trip either. That is why all all hand held bathroom type appliances (hair dryers, curling irons, flat irons) have immersion detection devices (the little box with the test/reset button) on it).
electures is offline   Reply With Quote
Old 06-16-2011, 12:03 PM   #19
So can i sit in a plastic bathtub full of water with the hairdryer with me? What good is a GFCI in a bathroom?
Old 06-16-2011, 12:19 PM   #20
I=E/R
a7ecorsair's Avatar
Since the electrical code doesn't dictate the plumbing code, it is entirely possible to have copper pipes supplying the water. The NEC establishes a minimum for safety. Having a GFCI doesn't hurt anything either.
Old 06-16-2011, 01:40 PM   #21
electures's Avatar
SO when you grab the hair dryer with one wet hand and the bathroom sink faucet with the other you don't get knocked on your a$$.
Old 06-16-2011, 02:42 PM   #22
I see the situation, the NEC and Plumbing Code are completely seperate. There is no way to know if the plumbing will complete the electrical path (plastic pipe vs. metal pipes).
Old 06-16-2011, 03:47 PM   #23
biggles's Avatar
take down your electric meter reading ##### might of drained some amps/watts but not enough to trip like running 2 hvac systems till you pulled it out..bill next month will tell ...rubber pool liner insulated the 115V from a grounding drain trip.see any dead flies in the pool
Old 06-16-2011, 11:03 PM   #24
dmxtothemax's Avatar
Rewards Points: 5,600
most people dont know this but,
Fresh clean water is NOT a good conductor of electricity,
So how much current flows depends on how much impurities,
or salt was in the water.
Saltly water IS a good conductor.
So the water the lead fell into was probably low in impurities
and or salt.
So not much current was flowing.
dmxtothemax is offline   Reply With Quote
Old 06-17-2011, 06:11 AM   #25
biggles's Avatar
good one low salt or dirt and the rubber liner no drain out
Old 06-17-2011, 07:34 AM   #26
Rewards Points: 101
I did find the problem. The GFCI near the front door had tripped, once I re-set it the plugs around the pool started working again.
michaelson is offline   Reply With Quote
Old 06-17-2011, 07:37 AM   #27
I=E/R
a7ecorsair's Avatar
That is one lucky dog
Old 06-18-2011, 01:13 PM   #28
Rewards Points: 101
Would the dog really have been killed had the GFCI not tripped?
Old 06-18-2011, 07:28 PM   #29
Knucklez's Avatar
Rewards Points: 942
ahh.. can't be that bad~?
Uploaded with ImageShack.us
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Inground Pool Leak - suggestions needed hravenkel Plumbing 10 03-21-2011 08:39 PM
TV power cord extention requirement cece Electrical 16 09-28-2010 03:53 PM
Pool Cement Apron Issue ajdevoll Building & Construction 7 09-08-2010 09:57 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 23 04-20-2009 01:45 PM
