Extention Cord Dropped Into Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 05:07 PM   #1
Rewards Points: 101
Extention Cord Dropped into Pool
This afternoon my dog pulled an extension cord into to our in-ground pool. It had been left alongside the pool plugged in and she somehow managed to get most of the cord into the pool, including the female end. I didn't discover it for a few hours after I'd let her in and I'm surprised that the breaker didn't blow. . . Shouldn't it?
michaelson is offline   Reply With Quote
Old 06-15-2011, 05:24 PM   #2
I=E/R
a7ecorsair's Avatar
Is the receptacle that the cord plugged into a GFCI? Is this receptacle still live? How did you get the cord out of the pool?
a7ecorsair is offline   Reply With Quote
Old 06-15-2011, 05:24 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Not really, but the gfci should have tripped.
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (06-15-2011)
Old 06-15-2011, 05:28 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
It may not have tripped the breaker. Did you look to see if any GFI's tripped though?
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Old 06-15-2011, 05:28 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by michaelson View Post
............... I'm surprised that the breaker didn't blow. . . Shouldn't it?
Why would it? Do you think the water alone would create a dead short? Or enough resistance to trip a 15 or 20A breaker?
Hint: No, it will not.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
electures (06-15-2011), SD515 (06-15-2011)
Old 06-15-2011, 05:35 PM   #6
Rewards Points: 101
A GFCI is the button on the outlet between the plug? If so, no, it doesn't have that. The outlet is not working anymore, but the breaker was not tripped.
I got the cord out by unplugging from the outlet and pulling the rest out of the water.
Old 06-15-2011, 05:36 PM   #7
Experienced
Jackofall1's Avatar
No it wouldn't, but this exactly why you need a GFI on any outdoor circuit, good thing "Mans best freind" didn't decide to go for a swim!
Mark
Old 06-15-2011, 05:38 PM   #8
jbfan's Avatar
Rewards Points: 140
You have a tripped gfci breaker, or receptacle somewhere.
Check the receptacle inside the garage.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
SD515 (06-15-2011), Speedy Petey (06-15-2011)
Old 06-15-2011, 05:46 PM   #9
...or even in the bathroom.
That's how my 1975 home was originally wired.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
J. V. (06-16-2011), jbfan (06-15-2011), SD515 (06-15-2011)
Old 06-15-2011, 06:23 PM   #10
Rewards Points: 101
I don't understand. . . How could dropping an extension cord into the pool blow GFCIs in the bathroom or garage? The cord was plugged into an outdoor outlet?
Old 06-15-2011, 06:30 PM   #11
Rewards Points: 6,652
It depends on how it was wired, and where the GFCI is located that feeds the outside outlet.
Old 06-15-2011, 06:31 PM   #12
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
GFI's protect themselves and any receptacle connected to the load side of the device. A lot of houses have GFI's @ the beginning of the circuit and are wired so as to protect everything downstream. They are generally located closest to the panelboard.
electures is offline   Reply With Quote
The Following 4 Users Say Thank You to electures For This Useful Post:
drtbk4ever (06-15-2011), gregzoll (06-15-2011), michaelson (06-17-2011), SD515 (06-15-2011)
Old 06-15-2011, 07:07 PM   #13
I=E/R
a7ecorsair's Avatar
As posted by others,
A GFCI receptacle will protect itself and it can be wired to protect several more receptacles in other rooms or outdoors. In my past house, the bathroom GFCI protected the receptacle in the garage. It took me a while to find that out when my garage outlet quit working.
Old 06-15-2011, 08:06 PM   #14
When ever I get around to it, my basement outlet that powers my workshop will be wired to the GFCI on the outside wall on the otherside of the shop. That will be a fun one for the next homeowner to figure out. Right now, it feeds off of another circuit that never got rewired, but on my list to do it once I am able to be back to better health to do this stuff.
Old 06-15-2011, 11:12 PM   #15
electures's Avatar
WHen GFI's were first introduced in the mid 70's (and I remember installing the first ones) we had problems with them tripping from refrigerators plugged into the garage receptacles. We used to wire all receptacles in the garage, basement, bathrooms and outside through one GFI. If the panel was in the garage then the garage receptacle got the GFI. If the panel was in the basement then the GFI went in the basement. SUcked when somebody on the second floor tripped the GFI and had to run to the basement in a bathrobe to reset the GFI. But that is what you get for low bid. Ironically there are those who think that a GFI will trip if something which is plugged into it is dropped into a tub. It probabely won't unless the drain system is metallic. With the new drain systems being plastic and the supply lines also being plastic the GFI will not trip. That is why hair dryers and other bathroom appliances have immersion detection devices molded onto the end of the cords.
The Following User Says Thank You to electures For This Useful Post:
oh'mike (06-16-2011)
Inground Pool Leak - suggestions needed hravenkel Plumbing 10 03-21-2011 09:39 PM
TV power cord extention requirement cece Electrical 16 09-28-2010 04:53 PM
Pool Cement Apron Issue ajdevoll Building & Construction 7 09-08-2010 10:57 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 09:59 AM
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 23 04-20-2009 02:45 PM
