Extension Cord Safety - My Husband's Theory - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 09:10 PM   #1
Learning by Doing
Leah Frances's Avatar
Extension Cord Safety - My Husband's theory
My Dear Husband has run an extension cord along a baseboard behind one of our steam radiators. It is the appropriately sized cord for the only thing that gets plugged into it (Laptop AC cord). Sometimes the cord ends up in contact with the supply pipe for the radiator. He is under the impression that the heat from the radiator will not hurt the cord. This seems hinky to me. All I could find on the UL website said you shouldn't drape it over hot surfaces, such as a radiator. Well, DUH! But what about under it?
Thoughts? Other than finding another husband?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-05-2008, 09:14 PM   #2
Union Electrician
goose134's Avatar
A steam radiator is unlikely to generate the heat needed to really do a number on the cord. That said, if it can be avoided, why not? The ones of great concern are the electric baseboard heaters. There are stickers on them that tell you not to hang drapes, cloth, and so on over them. These have surfaces that conceivably could ignite these types of things.
goose134 is offline   Reply With Quote
Old 02-05-2008, 09:50 PM   #3
Rewards Points: 1,418
If the steam enters at the top of the radiator, the underside won't be quite as hot as the upper part. Still, some heat "radiates" downward. (As radiant energy in addition to the heat picked up by air (convection) moving upward (heat rises) through the radiator.)
The radiant energy is enough to accelerate the biodegrading of the extension cord insulation, namely the insulation might start to turn brittle and crack three years from now as opposed to eighteen.
Old 02-05-2008, 09:54 PM   #4
Learning by Doing
I've got a good IR thermometer. Is there somewhere I can find optimal operating temperatures for extension cords?
I can't rebut my DH with anything but cold hard facts.
Old 02-05-2008, 09:57 PM   #5
Union Electrician
goose134's Avatar
The conductors inside should have their rating printed on the cord itself. As for the jacket, I'd have to say that either the NEMA website or the manufacturer would have something.
Wait. You don't know who made your cord, do you?
Let me check a few things. I'll report back.
Old 02-05-2008, 10:15 PM   #6
Union Electrician
goose134's Avatar
Leah, I checked around and the jacket on the cords have a wide variety of limits. One was as high as 250 deg.F. Most were in the 120-140deg range. Shoot your temp scanner at the radiator at full heat and see what you find. I agree that even though it may not exceed limits, it will probably shorten the life of the cord.
Your husband being who he is, may need docs. on this and if pressed, I could link them. Who is, by the way, much like myself. I almost feel like I should live in Missouri.
Old 02-06-2008, 05:26 PM   #7
joed's Avatar
Rewards Points: 11,516
I don't think the heat from the radiator will damage the cord. However you should install a proper receptacle so the cord does not need to be used. Cords are for temporay use. This is not a temporary use.
Old 02-06-2008, 05:47 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Reconsider your thoughts on a new husband in some womens worlds they are much like extension cords as Joe said ........ for temporary use.
Old 02-06-2008, 06:03 PM   #9
hinky ?
nacko is offline   Reply With Quote
Old 02-06-2008, 06:06 PM   #10
yummy mummy's Avatar
Rewards Points: 1,016
I say go for a new husband
yummy mummy is offline   Reply With Quote
Old 02-06-2008, 11:06 PM   #11
Power Gen/RS Engineer
Rewards Points: 566
Yummy, you have waaaay too much to take care of with your vapour barrier (and you best friend Atlantic) to be quipping here!
Carry on!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 02-07-2008, 10:13 AM   #12
Carry on!
this forum is my relaxation.........and yes Atlantic is my favourite........
Old 02-07-2008, 11:27 AM   #13
Rewards Points: 58
Extension devices and cords are one of the most dangerous methods out there. Never use an extension cord for permanent use. Even for TV's ect... Protected power extension strips are the exception.
The NEC prohibits the use of cords as you have described. Its a violation and dangerous (fire hazzard). Get rid of that cord today and get an outlet installed.
Having a real problem is about a million to one, but people do win lotteries.
Old 02-07-2008, 05:46 PM   #14
Sparrky
how about springing for a couple of extra batteries for the Lap Top in exchange for the cord you can dump into the round file..give him some excra batts and an charger and maybe you'll wean him off the cord no-no ?
Kingsmurf is offline   Reply With Quote
Old 02-08-2008, 08:32 AM   #15
Learning by Doing
The NEC has yet to prove to be a persuasive during a spousal debate in my nearly ten years of marriage. I understand that this is a bad idea. My DH does not. That's why I was hoping to find some 'hard evidence' that putting the extension cord there was a problem.
FYI: he got another new battery for Xmas. It came with another AC cord for the laptop - hence his idea to put the extension cord behind the radiator, so he could have yet another place to plug his computer in.
extension cord draining power? mt232 Electrical 14 05-25-2011 04:37 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
Help w/Welding Machine Extension Cord ThePlumber Electrical 1 07-23-2006 11:27 AM
Extension Cord Question. camoram Electrical 2 04-08-2006 10:12 PM
