#1 |
Extension cord question
I just replaced the male end of an extension cord. Inside the cord, only the ground (green) wire was colored, the other two were both white. Is there a way to test it to make sure i got the hot wire and the neutral wire correct without damaging anything?
Thanks. |
#2 |
Licensed electrician
A multimeter with a continuity function could ring out the conductors.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | plummen (02-14-2012) |
#3 |
There are also outlet testers that tell if an outlet is wired correctly. You could plug one of these into the female end of the cord.
| The Following User Says Thank You to a_lost_shadow For This Useful Post: | plummen (02-14-2012) |
#4 |
It was a dark and stormy
Or if you have a properly wired grounded outlet and any table lamp, you've got a continuity checker.
#5 |
Plugging a lamp into the cord would not show if it was wired correctly. The lamp will work the same even if the wires are crossed on the terminals. The difference would be the shell would be hot instead of the tab in the bottom of the socket. The chance of shock from contact with the hot shell would be increased.
| The Following User Says Thank You to Jim Port For This Useful Post: | brric (02-14-2012) |
#6 |
I'll assume it's a flat cord with a green ground wire. One side of the cord will be ribbed, the other not. The ribbed side is your neutral.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
I guess I should have explained.
While taking appropriate precautions use a lamp with clip leads on the plug to find out which of the two outlet slots show voltage with respect to the ground hole. Call it H. At the source end of the cord put the green wire into the outlet ground hole and either white wire into the H slot. At the destination end of the cord put one lamp lead onto the green wire and test which white wire lights the bulb. That's your H wire. With multiconductor cables this can get pretty tedious but with the OP's cable the test is trivial. Last edited by Yoyizit; 02-15-2012 at 11:29 AM. |
#8 |
Do you have the end of the original cord that you cut off? You could plug that in and carefully test it. Also, if you can get the orientation of the cord right (ground down), the hot will be on the right.
#9 | |
Doing it myself
Extension cord questionQuote:
Journeyman Plumber |
#10 |
Extension cord question |
#11 |
Take a guess and put it together. Plug in one of the three light testers. If it reads hot & neutral reversed then take apart and change it. Test the wall socket first to make sure it is wired correctly.
Do not PM with questions that can be asked in a forum. I will not respond. |
| The Following User Says Thank You to joed For This Useful Post: | zappa (02-16-2012) |
| Display Modes | |
| 220v to 110v extension cord? | glamabilly | Electrical | 14 | 09-26-2010 12:25 AM |
| Extension cord fire | KE2KB | General Discussion | 8 | 07-04-2010 11:52 AM |
| Extension Cord Safety | KE2KB | Electrical | 23 | 01-20-2009 10:11 PM |
| Pull cord light question | 737Pilot | Electrical | 5 | 12-21-2008 10:49 AM |
| Ganged Extension Cord | Rze | Electrical | 15 | 08-04-2008 06:27 AM |
