Extension Cord Plug ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2008, 03:54 PM   #1
wel
extension cord plug ?
I am looking at using a generator transfer switch that has a L14-30 connection.My generator is a L14-20. I am looking at making a 20' cord out of 10-4 so and putting a 20 amp male(generator end) and 30 amp(switch end) Any problem with this?
wel is offline   Reply With Quote
Old 07-15-2008, 04:17 PM   #2
Having two male plugs can be very dangerous and is not allowed. Can't you wire it in hard to the switch?
BillyD is offline   Reply With Quote
Old 07-15-2008, 04:33 PM   #3
wel
I think you misunderstood.I will be putting a male 20 amp plug and a female 30 amp plug.The switch is set up for a 30 amp 7500 watts max.My generator is only 5kw and has a 20 amp receptacle.I don't think it will be an issue since the gen is fused at 20 amps and the so cord and both plugs are 4 wire.I just wanted some more qualified opinions.
WEL
Old 07-15-2008, 06:34 PM   #4
Sorry I miss understood. That will work fine
extension cord draining power? mt232 Electrical 14 05-25-2011 03:37 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
Extension Cord Safety - My Husband's theory Leah Frances Electrical 18 02-09-2008 06:06 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Extension Cord Question. camoram Electrical 2 04-08-2006 09:12 PM
