Extension Cord Mod - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 02:56 PM   #1
Extension Cord Mod
Hi All,
Is it safe to cut the female end off a 3-prong extension cord and wire it in to feed a light socket from a normal receptacle ? It's for the garage and I don't want to tear into anything.
Idea is:
Existing plug -> 3 prong grounded timer -> male end of extension cord -> octagon box with light socket tied into the cut female end of the cord
Thanks, Chazz
chazz is offline   Reply With Quote
Old 01-15-2010, 04:25 PM   #2
Electrician
Rewards Points: 794
Your idea is not correct, your not allowed to use extension cord for a permant installation.
One option is to get this type of extension ring http://www.tnb-canada.com/en/catalog...xes_04_eng.pdf
Go down and look at the 1110r. If you find one these you can put this on your exisitng plug. This will bring out the box past your wall, then you will be able to run whatever type of wire you need(romex, bx, or even pipe) out of the extension ring.
darren is offline   Reply With Quote
Old 01-15-2010, 05:50 PM   #3
I agree.
There have been a lot of fires caused by extension cords and the like!
And electricity wired wrong still works!
The safest way to do this would be to read a book on home electrical wiring cover to cover (sold at home improvement stores). Get one with plenty of pictures so you can see how wiring is typically done.
Safer is to make a simple wiring diagram of what you plan to do, then get an electrical permit from your city or county. Then have an electrical inspector check your work to be sure it is safe. Not too much cost for a small project.
Billy_Bob is offline   Reply With Quote
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 07:25 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
