Extension Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 04:26 PM   #1
Rewards Points: 278
Extension Box
The polaris copper to aluminum connector is a little bulky, I think I need an extension box, to make the volume bigger. I am using a cooktop and there is space behind the cabinet,
extending the box is OK right?
Are the extenders metal or plastic? I have not seen one, does it attach with 4 holes to the corner of a square cover box?
DIYGST is offline   Reply With Quote
Old 03-03-2009, 05:40 PM   #2
Remodeling Contractor
4" extension boxes are available and would add the the allowed volume. But these are attached with two screws, not four to the box. you can also use extension (P-Rings) rings which will provide the screw positions for the cover plate.
Old 03-03-2009, 05:52 PM   #3
Rewards Points: 278
4" is too much extension, another 1" or so might be good.
I was concerned about how it attaches, because the builder simply cut out plastic on top to let the 8 gauge cable come from the top, I suppose the cable is too thick.
it only have provision nows to attach a square cover with 4 screws.
Old 03-03-2009, 07:20 PM   #4
4" is the size of the box, not it's depth. Extension boxes are 1 1/2" deep. P-Rings are flat to 2" deep with 1/8" increments
Old 03-05-2009, 12:52 PM   #5
Rewards Points: 78
Must it be mounted flush? If not, you can get a deeper box and surface mount it behind the cook top or range. Would be much easier and compliant.
Old 03-05-2009, 03:15 PM   #6
Licensed electrician
Rewards Points: 1,234
Why are you pigtailing copper to the aluminum wires?
Is this a new install with new wires?
Old 03-05-2009, 04:34 PM   #7
Rewards Points: 278
Old house, and appliance comes with copper wires
I have had a long question here before and the polaris connectors are approved to join them safely.
extension cord draining power? mt232 Electrical 14 05-25-2011 04:37 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 10:11 PM
Concrete Patio Extension redhermes Building & Construction 14 11-18-2008 11:09 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 06:14 AM
300# versus 250# extension ladder Plasmech Tools 6 04-10-2008 04:53 PM
