-   -   Extension Box (http://www.diychatroom.com/f18/extension-box-39577/)
DIYGST 03-03-2009 04:26 PM
Extension Box
The polaris copper to aluminum connector is a little bulky, I think I need an extension box, to make the volume bigger. I am using a cooktop and there is space behind the cabinet,
extending the box is OK right?
Are the extenders metal or plastic? I have not seen one, does it attach with 4 holes to the corner of a square cover box?
Bob Mariani 03-03-2009 05:40 PM
4" extension boxes are available and would add the the allowed volume. But these are attached with two screws, not four to the box. you can also use extension (P-Rings) rings which will provide the screw positions for the cover plate.
DIYGST 03-03-2009 05:52 PM
4" is too much extension, another 1" or so might be good.
I was concerned about how it attaches, because the builder simply cut out plastic on top to let the 8 gauge cable come from the top, I suppose the cable is too thick.
it only have provision nows to attach a square cover with 4 screws.
Bob Mariani 03-03-2009 07:20 PM
4" is the size of the box, not it's depth. Extension boxes are 1 1/2" deep. P-Rings are flat to 2" deep with 1/8" increments
J. V. 03-05-2009 12:52 PM
Must it be mounted flush? If not, you can get a deeper box and surface mount it behind the cook top or range. Would be much easier and compliant.
Jim Port 03-05-2009 03:15 PM
Why are you pigtailing copper to the aluminum wires?
Is this a new install with new wires?
DIYGST 03-05-2009 04:34 PM
Old house, and appliance comes with copper wires
I have had a long question here before and the polaris connectors are approved to join them safely.
