Extending Wire For Electric Range - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 04:45 PM   #1
Extending wire for electric range
I want to know if its ok to install a juction box and then extend the wire for my electric range in order to move it to the new main panel we installed, rather than installing a new run right from the range (its a long ways). I know the juction box has to remain accessible but are there other issues with doing it this way?
rovers1973 is offline   Reply With Quote
Old 03-17-2010, 04:57 PM   #2
Journeyman Wireman
Rewards Points: 150
In the US you would need to run a 4 wire cable (2 hots, neutral, ground) to the new location. If that is what exists in your current run, no problem to splice in a j-box and continue the run. If it's only a 3 wire cable, you need to go back to the panel.
If you do splice, use an insulated splice "boot" rather than wire nuts or split bolts. Polaris is a brand we can get here.
Hopefully some Canadian will chime in if there are different issues in B.C.
Jupe Blue is offline   Reply With Quote
Old 03-17-2010, 05:00 PM   #3
Electrician
Rewards Points: 782
No problem with your plan, even if it is an old 3 wire feed I wouldn't think you would to need to change it since your not touching the stove or the stove plug.
darren is offline   Reply With Quote
Old 03-17-2010, 05:09 PM   #4
Thanks for the input guys, much appreciated. (It is 4 wire by the way).
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 05:13 PM
Need help on Electric range wiring rarquilla Electrical 20 11-20-2008 08:00 PM
