#1 |
Extending ungrounded wire to new panel
I installed an new 200 amp breaker box to the right of my existing box. A few wire runs coming from the left side will need to be extended in order to reach the new box. They are ungrounded. 2 of these runs are accessable in my basement so I plan to rewire the basement circuits immediately with 12/2 romex. However, 2 are not easily accessible and travel to an upstairs bedroom through an outside wall. They will be very difficult to run new wires. In the meantime I'd like to use a junction box next to my breaker and extend the wires to the new box. My question is what is the acceptable way to lengthen these ungrounded wires? Do I use the 12/2 romex and just cap off the ground on both ends? Do I pull the ground wire out of the romex and wire into the new box without a ground? Do I use Romex and ground the junction box? Each of the runs will need to be lengthened by 3'-4'.
I could use the older ungrounded wire that I replace in the basement to extend these runs. But I'd prefer not to. Aside from running a new wire upstairs whats the best option here? |
#2 |
Electrical Contractor
Run the romex, and leave the ground wire intact and connected in the panel.
If you use a metal box, connect the ground wire to it.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| The Following User Says Thank You to jbfan For This Useful Post: | speedster1 (08-03-2012) |
| Display Modes | |
| Wire for 100 amp panel | rocklobster | Electrical | 13 | 01-11-2012 07:29 PM |
| EMT and WIRE size - 100 amp sub panel | balansaj | Electrical | 6 | 05-18-2010 04:17 PM |
| Main grounding electrode wire to panel | rovers1973 | Electrical | 4 | 03-18-2010 07:18 PM |
| Multiple Panel Question | theatretch85 | Electrical | 5 | 12-12-2009 06:26 AM |
| Future wire in panel? | wease | Electrical | 20 | 05-10-2009 04:28 PM |
