Extending Length Of Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2006, 01:10 PM   #1
Extending length of wire
I'm trying to relocate an exisitng switch but the wire is not long enough. Is there a way to extend the wire without rewiring the entire room. The switch that I intend to relocate is on the third floor and the main breaker is in the basement at the other end of the house. Fishing a new wire is close to impossible. My neighbor extended his by running a new wire from the exisitng switch to the new locatioin and then concealing the box behing the drywall. Is that legal? Please help....:confused:
wingman is offline   Reply With Quote
Old 03-05-2006, 01:25 PM   #2
jproffer's Avatar
Rewards Points: 706
Any splice you do to add length HAS to be in a junction box and HAS to be accessible...forever. You can't leave it in the wall behind the sheetrock.
jproffer is offline   Reply With Quote
Old 03-05-2006, 01:49 PM   #3
Any other suggestion??
Any other suggestion besides a junction box? I don't want to have junction box on the wall in a bed room.
Old 03-05-2006, 03:30 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Of course you do not have to go back to the main panel. You simply need to find a place to put an accessible j-box.
You say this is third floor? How about in the attic? Is there one above?
Old 03-05-2006, 03:32 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
A receptacle/switch box is smaller than a j-box, and also comes with a solid cover plate.
You have to use one or the other. The cover can be covered with wallpaper or painted to blend with the location, but it has to be accessible, as stated.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-05-2006, 05:04 PM   #6
Location
Since the main thing is for it to be accessible can this switch box be located on the ceiling?
Old 03-05-2006, 05:28 PM   #7
jproffer's Avatar
Rewards Points: 706
Hmmmm...I don't see why not.
Old 03-05-2006, 06:47 PM   #8
joed's Avatar
Rewards Points: 12,028
What's on the other side of the wall? The box could be turned around and mounted on the opposite wall.
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
