Extending Cable For Garden Solar Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2009, 05:58 AM   #1
Cool
Extending cable for garden solar lights
I have a question re Extending the cable for my garden solar lights
I have a set of fusion rock lights as shown on http://www.thefinelightingcompany.co...r/default.aspx
I need to place the solar panel in the direct sunlight so therefore need to extend the cables going to the lights ( which house the rechargeable batteries) I want to extend one cable by approc 5m and the other by 10m the third will be ok I wondered if I will get significant losses by extending the cables Vs the gain from having the solar panel in direct light instead of constantly in the shade ( not very bright when these ones come on ) perhaps if I use heavier cable to extend this may help.
The solar panel is described as 1.8W mono crystal the batteries ar 3* 1.2V nimh AA 150mah per unit supplies 3* LED cable supplied is 4.8m for each of the three lights
Hope this enough info If the cable lengths I want are too long maybe a suggestion could be made as to the maximum I should use.
Best regards
Calibra
calibra is offline   Reply With Quote
Old 09-02-2009, 07:47 AM   #2
There should be no problem in extending the cables as the current/resistence (IR drop) is so small that it will easily be overcome with the higher voltage from the direct sunlight. I recommend replacing the entire cable with a good outside low-voltage cable as splices always seem to have problems being exposed to weather.
RetiredKeith is offline   Reply With Quote
Old 09-02-2009, 08:26 AM   #3
Re solar light cable extending
I will not be able to extend the complete cable as the rock lights appear to be sealed units !!!!! so can`t get access to termination...I assume I should use same grade cable as fitted....
thanks
(Also) Keith
Old 09-02-2009, 10:47 AM   #4
Rewards Points: 1,016
If you can't get into the units due to being sealed, then the option is to splice the extention into the existing wire.
Solar Powered XMas Lights??? mandarinmint General DIY Discussions 4 11-27-2008 08:14 AM
repairing solar powered lights radar Electrical 1 05-12-2008 12:12 PM
outdoor lights cable cut ASantosdiaz Electrical 2 11-01-2007 01:24 PM
