Ext Motion Senesor And Inside Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 08:41 AM   #1
ext motion sensor and inside wall switch for one light
Can an existing outside light be controlled by both a motion sensor and an inside wall switch? Not sure how to approach. What sensor to select and how the 2 way would be wired if so.
Thanks for any feedback
redrumliny is offline   Reply With Quote
Old 09-04-2009, 11:41 AM   #2
Typically the switch would send/kill power to the motion sensor/light fixture.
On most models, if you want to turn the light on, you flip the switch on/off/on and it will stay on (night time only)
220/221 is offline   Reply With Quote
Old 09-04-2009, 11:47 AM   #3
Rewards Points: 126
Yes. It's done all the time. You can use the switch to bypass the sensor if you like, or just use the switch to turn it off completely. I like to leave the sensor hot all the time. That way if the switch is off, the light will still come on.
Old 09-04-2009, 12:41 PM   #4
How does one wire it like this? This is what I am looking for. Suggest any sensors? Thanks for the feedback.
Old 09-04-2009, 12:48 PM   #5
I gather then if I want the light to go off but back into sensor mode I hit the switch on/off/on again and its back in business?
Old 09-04-2009, 01:30 PM   #6
300zx's Avatar
Post
To turn back to sensor mode turn switch off and wait a few seconds and turn switch back on and you are good to go.
300zx is offline   Reply With Quote
Old 09-04-2009, 01:47 PM   #7
This will be done all from the inside ~ existing ~ light switch???
Want to use existing exterior light and existing inside wall switch and add the sensor to the set-up.
Sorry if I am green on this ~ Do appreciate the help ~ TY
