Ext. Cord Inside Cabinets? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 12:46 PM   #1
Rewards Points: 278
Ext. cord inside cabinets?
So I have put an outlet inside one of my kitchen cabinet, and this cabinet has a cut-out to access the receptacle. Now I found I may want to power something in 2 cabinets away. Then it would be OK to drill through the cabinets and run an ext. cord through them?
The cord will be behind drawers so it won't be visible unless the drawer is taken out.
This is because I am consider adding an actuator to automatically open one of the drawers, but not sure of the commiting yet. It may be possible to keep the 120V power supply in the far carbinet and extend the DC wires also.
DIYGST is offline   Reply With Quote
Old 02-01-2010, 01:03 PM   #2
Inspector/Instructor
codeone's Avatar
A person can do anything they want to.
However this is not allowed per the NEC !
codeone is offline   Reply With Quote
Old 02-01-2010, 01:04 PM   #3
Rewards Points: 278
Thanks. I will think about extending the DC wire which seems more safe
Old 02-01-2010, 01:35 PM   #4
Just call me Andrew
Rewards Points: 1,020
You could probably stay to code by using a raceway to extend your circuit to an outlet in another cabinet. Easier than running wires in the walls, and it won't be visible since it's inside a cabinet.
Andrew
secutanudu is offline   Reply With Quote
Old 02-01-2010, 01:42 PM   #5
Rewards Points: 278
what is a raceway?
It would be easier to run just an armored cable.
What about NM cable? is that allowed through cabinets?
Old 02-01-2010, 01:45 PM   #6
codeone's Avatar
Originally Posted by DIYGST View Post
what is a raceway?
You could as long as you sleeved it in any areas it might be hit by something.
Old 02-01-2010, 01:46 PM   #7
Just call me Andrew
A raceway is a type of conduit that is meant to be surface-mounted:
http://www.homedepot.com/webapp/wcs/...atalogId=10053
You would not want to run bare NM cable in a cabinet. To easy for it to get damaged by boxes, pots, pans, etc. My thought was you could run NM inside a raceway.
Not sure about armored cable, might be ok.
Andrew
Old 02-01-2010, 01:49 PM   #8
Rewards Points: 278
Is there a face plate for a remodel single gang box so that it gives a 1/2" knock out so that open up options to smurf or armored cable.
I don't think you are supposed to put cords in the wiremold raceway only NM..
Old 02-01-2010, 01:57 PM   #9
Rewards Points: 278
I think I would also consider run those blue smurf conduits, snake it through, and run the DC wires through the area purely for protection..
even though it won't be possible for anything to exist in the few inches behind the drawers, the conduit will help them stay in place.
Old 02-01-2010, 02:24 PM   #10
Just call me Andrew
I was not suggesting you run the extension cord through the raceway. I was suggesting NM inside the raceway.
Also - what do you mean by "DC wires"? Most normal residential wiring is AC. Not trying to nitpick, just want to make sure we are talking about the same thing.
Andrew
Old 02-01-2010, 02:35 PM   #11
Just call me Andrew
I think wiremold makes surface-mounted boxes for outlets/switches. This one look like it comes with the outlet:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Andrew
Old 02-01-2010, 02:38 PM   #12
Rewards Points: 278
One option I am thinking is put the transformer in the same cabinet, and run the DC low voltage wire for the actuator the the destination. NEC does have low voltage rules but I am not familiar with them.
Old 02-02-2010, 07:48 AM   #13
Just call me Andrew
Oh, I missed the fact that you are doing low voltage. I am unfamiliar with the NEC's rules on it as well.
Andrew
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Upgrade inside kitchen cabinets WATSONJ Kitchen & Bath Remodeling 2 01-03-2009 12:22 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
