Exposed Wiring - Would This Be Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 12:47 PM   #1
Question
Exposed wiring - would this be Code?
Hi,
I own a house. The previous owner installed a garage door opener which came with a standard electrical plug. He plugged this into an extension cord and the cord into a wall outlet.
As far as I understand (Ontario, Canada), this is not up to code since it is a "permanent" fixture.
Since I am doing some other electrical work (which will get inspected), I thought I can fix this one too for the same price.
The standard way to do it would be to fish a cable inside the drywall to the outlet and do a permanent connection there. However, I would rather not fish in the garage and risk screwing-up the vapour barrier since my son's room is on top and don't want any gas vapour / combustion gases seeping through.
Would it be to code to simply staple #14 x 2 Romex to the drywall and then driving it into the receptacle at the receptacle level? Or will this "exposed" cable be considered not up to Code?
Alternatively, how can I surface-mount / run Romex that would be compliant?
globus999 is offline   Reply With Quote
Old 09-14-2010, 01:06 PM   #2
Rewards Points: 330
wire mould.check codes but that would be best for what you want to do.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
globus999 (09-14-2010)
Old 09-14-2010, 02:33 PM   #3
Rewards Points: 156
How about conduit?
creamaster is offline   Reply With Quote
Old 09-14-2010, 06:07 PM   #4
Rewards Points: 330
wire mold will look better.just for one outlet,for openner is all you need.
Exposed dishwasher wiring secutanudu Electrical 15 04-20-2009 10:44 AM
Question about exposed junction box on floor & code BradG Electrical 9 03-21-2009 11:05 AM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 05:58 AM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 07:58 AM
