#1 |
Exposed WIRING ON BOTTOM OF JOISTS.
I am selling my house and the Home Inspector said that the basement surfaced mounted receptacles needed to be in conduit because the wires were exposed. He didnt say anything about the exposed wiring that was stapled to the bottom of the joists had to be in conduit. Can I just leave the exposed wires on the joist exposed or do I have to but them in conduit too? Could I also just drill the joists out and run the wire inside them? Is there a code about this? Did the Home Inspector forget this? What would happen if I only fixed the receptacles with conduit and nothing else? Thanks In Advance!
#2 |
Licensed electrician
Perhaps the HI was considering the cables as subject to physical damage. Was this work inspected when it was installed?
The HI can put anything in their reports, including going above and beyond the actual code requirements. All of these issues are negotiable items to be worked out between the buyers and sellers. The HI cannot mandate anything to be done as they have no enforcement powers.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | a7ecorsair (04-30-2012) |
#3 |
Licensed Electrician
Pictures would help here.
Where are you located? There are local codes that may dictate what you need to do. A community where I do work only allowed 18" of exposed romex in a basement for example. In an open basement romex smaller than 6-3 has to be drilled thru the joists and has to be protected where it comes down a wall per the NEC. When I have been sent to a customer's house to comply with a home inspector's report, 10 times out of 10 a licensed electrician with benefit of a permit is specifically required. I wouldn't do anything till you have something in writing. |
#4 | |
Exposed WIRING ON BOTTOM OF JOISTS.Quote:
but jim is correct in that the home inspector can only point out problems and make recommendations. they can't dictate anything. only time that can become an issue is if the buyer's mortgage provider won't approve the loan unless the recommendations of the home inspector are implemented. |
#5 | |
#6 |
I live in New Albany Indiana. The home was built in the 1950's & In the basement it looks like someone 3 yrs ago added some exposed wiring for the surface mounted receptacles on the walls. The wiring on the walls is the same wiring on the basement ceiling but stapled every 2 ft. Surely when he said to put wall plugs in conduit did he mean the ceiling too? The exposed wiring on the ceiling should be in conduit too shouldnt it? Or can I just drill out the joists? What would you do? Yes the wiring is NM romex.
#7 |
Jack of all - master none
From what I was told by an electrical inspector here (your mileage may vary) if the NM-B is above the bottom of the joists, it is allowed (i.e. drilled through the joists). Any NM-B below the bottom of the joists is not allowed, and must be protected in-wall or wired in conduit.
(EDIT: I am outside of the crazy-electrical-rules region of Chicago) |
#8 |
In a little over my head
I'm not an electrician or inspector. But unprotected wires on a wall are much more susceptible to damage than wires on/above the ceiling.
#9 |
Sorry guys. The HI said in writing that the wall receptacles in the basement had to have conduit on the wire (NM) because it is considered exposed. My question is did he forget to mention in writing the ceiling too or did he mean both because the wires (NM) on the celing feed the wall recptacles? What I dont want to happen is that I put wall receptacles in conduit as asked but then he will turn around and say why didnt you drill out studs or put wiring (NM) in conduit too? What to do? Cant call him, no number on report to call.
#10 | |
Cruising into the sunset
Even if I moved and built a house somewhere in Romexland, I would still put conduit all through my house. Many of the problems I see here would be either easier to solve or wouldn't be a problem if conduit was installed. |
#11 | |
Licensed Electrical Cont.
NM CAN be exposed, unless it is subject to physical damage. To satisfy the buyers just put a wood running board up next to the wiring and walk away. That will satisfy code and the HI. He CANNOT dictate HOW you correct something. In fact that is not within the scope of their work. Their job is to point things out, nothing more.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| The Following 2 Users Say Thank You to Speedy Petey For This Useful Post: | frenchelectrican (05-01-2012), pp2815 (04-30-2012) |
#12 | |
![]() the home inspector isn't like an ahj or anything like that with any real power to directly dictate what needs to be done. his recommendations may be required by the mortgage company or insurer or similar and in that way, he is indirectly having power. |
| The Following User Says Thank You to itsnotrequired For This Useful Post: | k_buz (04-30-2012) |
#13 | |
" Euro " electrician
Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
| Display Modes | |
| Bubba's been here. Repairing sagging rim/floor joists. | MattFels | Building & Construction | 7 | 02-09-2011 06:28 PM |
| Supporting joist under cracked tile | JT31 | Building & Construction | 2 | 08-26-2010 09:00 AM |
| Floor Joists of different sizes | HooKooDooKu | Drywall & Plaster | 7 | 02-04-2010 06:43 PM |
| Should I paint the Crawl Space Wood Joists? They are exposed? | twilightcall | Painting | 11 | 09-21-2009 09:46 AM |
| Wiring the bottom of a chandelier | maged | Electrical | 12 | 06-04-2009 02:36 PM |
