Exposed Wires Underground - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 04:25 PM   #1
I have electrical wires protruding from the side of my brick house. It was previously connected to an outdoor light that sat atop a low brick garden wall. I had the wall removed but then had about six feet of wire coming from my house to a light I no longer needed. I cut the wire to about 18 inches from the house then wrapped the end in electrical tape and buried it in the ground about three inches.
Is this a total hazard and breaking all kinds of code? Both electrical and common sense ones?
What is the proper solution that isn't a safety hazard? I thought about maybe "installing" a weatherproof outdoor outlet box that this wire could connect to. Or is there a proper way to cap off this now unused wire if a box is out of the question?
HertzNewbie is offline   Reply With Quote
Old 11-23-2012, 04:34 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 234
Install the box and put wire nuts on the end of the wire.
We won't go into your current solution!
Old 11-23-2012, 04:42 PM   #3
bbo
the solution I would use:
find out where its terminated inside the house.
shut off that breaker.
verify again no voltage going to that junction box.
remove termination inside the house ( probably wire nutted inside a junction box)
seal junction box back up ( put cover back on and screw down)
remove wire inside house ( cut next to wall going outside )
go outside and pull wire all the way out and remove and throw away all wire.
turn breaker back on and verify all is well.
-seal hole in wall to keep vermin out.
bbo is offline   Reply With Quote
Old 11-23-2012, 06:57 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,102
Only if you are 100% sure that the supply end of the cable is
completely disconnectted !
And the end of the cable clearly labelled,
so no one is tempted to hook it up again
not knowing where it goes.
As for code issue's it's probably a grey area !
dmxtothemax is offline   Reply With Quote
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
wires left exposed dangerous??? pawlina Electrical 5 03-21-2012 10:29 AM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 04:00 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
