Exposed Seathing On Hot Wire In Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 04:32 PM   #1
Rewards Points: 398
A hot wire in my box had some sheathing wore off - is it ok to wrap that portion with electrical tape? There's not really enough room to cut it back.
Exposed seathing on hot wire in box-image-3619091192.jpg   Exposed seathing on hot wire in box-image-1643208456.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 10-24-2012, 03:32 PM   #2
Might be my phone but that looks like an old heat damaged conductor. You can tape what you can see but I'd be concerned about what's in the wall.
Evstarr is offline   Reply With Quote
Old 10-24-2012, 04:16 PM   #3
Rewards Points: 398
I replaced the box because the old one was very worn and loose around the drywall. When I had removed the drywall I didn't see anything that stood out but I don't know what was beyond what I could see.
I'm wondering if it happened when I was using my pliers to help pull the wires through the new box
Exposed seathing on hot wire in box-image-564724014.jpg   Exposed seathing on hot wire in box-image-1188304242.jpg   Exposed seathing on hot wire in box-image-2816921768.jpg
Old 10-24-2012, 04:31 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Bingo!
Electrical tape will do the job.
sublime2 is offline   Reply With Quote
Old 10-24-2012, 07:18 PM   #5
joed's Avatar
Rewards Points: 12,334
I would not trust electrical tape. I have seen too many pieces that after time and temp just fall off. Some proper voltage rated heat shrink would be OK by me however.
The Following 2 Users Say Thank You to joed For This Useful Post:
jbfan (10-24-2012), sublime2 (10-24-2012)
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
Exposed pool ground wire, can I just cut it? Drywallhelp Electrical 14 08-28-2011 04:25 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
