Exposed Electrical Wiring In Basement Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 02:39 PM   #1
exposed electrical wiring in basement ceiling
Can I run exposed electrical wiring on the ceiling of my basement and simply staple every 18 inches?
zemdegs is offline   Reply With Quote
Old 01-03-2011, 04:20 PM   #2
joed's Avatar
Rewards Points: 11,560
Is it a finished ceiling? If it is then you are fine. If it is not finished then you need running boards to protect the cable.
Old 01-03-2011, 04:29 PM   #3
WaldenL's Avatar
Rewards Points: 268
Is there a difference between "on" the ceiling, and "in" the ceiling? IOW, if the wires run across the bottom of the joists in an unfinished ceiling is that different than if the wires run through holes in the joists? I can't imagine running boards to protect all the wires running through holes in the joists.
WaldenL is offline   Reply With Quote
Old 01-03-2011, 06:06 PM   #4
joed's Avatar
Though holes does not requires running boards. I have been told it is to prevent you from using the cable as a clothes line.
Old 01-03-2011, 06:08 PM   #5
WaldenL's Avatar
Rewards Points: 268
My understanding too. But I could always hang my laundry on the wires that go through holes too! :-)
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
