Explosion - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 11:42 PM   #1
Explosion
I suffered some burns today when an explosion occurred as I plugged a kitchen stove into a 3 prong 220 wall outlet.
as soon as contact was made, a powerful and very bright blast ejected the plug and left my hand, the plug, and a little bit of the wall scorched.
The receptacles for the two live prongs are now joined by some melting damage.
The corresponding prongs have lost a little mass, about pencil eraser size round at the base, presumably vaporized.
I do not know the amperage at this time, will get that info tomorrow.
All the wiring appeared to be in order, a more thorough investigation had to be put off as I sought professional medical consultation.
WHAT HAPPENED?
What kind of temperatures could we be talking about?
(cross posted here: http://www.diychatroom.com/f45/explo...93/#post964552 )
squarenuts is offline   Reply With Quote
Old 07-12-2012, 11:58 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There was something wrong with either the range or the receptacle. From the size of the arc flash, it sounds like either one of those two shorted out phase to phase.
Old 07-13-2012, 02:05 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,938
Sounds like a dead short in the stove. The circuit was almost certainly on a 50A breaker, but the instantaneous fault current is MUCH higher - probably on the order of 1000A for about 1/5 second until the breaker trips. Temperature? Somewhere around 10,000-30,000 Fahrenheit is typical for most atmospheric arcs. The temperature of the plasma is less important than the radiant heat from it, which is what does the damage. It's pretty unlikely that there was any danger of really serious injury from this kind of incident though. The available fault current is just not high enough to cause an arc flash like this:
http://www.youtube.com/watch?v=W6Im7...1&feature=plcp
(Note: the incident in this video is reported to have been fatal for one of the workers.)
mpoulton is online now   Reply With Quote
Old 07-13-2012, 08:53 AM   #4
Bill Kearney
Rewards Points: 1,174
All the more reason never to connect a heavy appliance like that without shutting off the breaker first. Sure sounds like the stove has a dead short in it, or someone mis-wired that outlet some time in the past, for a likewise mis-wired stove that used to be connected to it.
wkearney99 is offline   Reply With Quote
Old 07-13-2012, 09:08 AM   #5
Rewards Points: 6,652
Always have the breaker off, when plugging this stuff in, after inspecting it for proper operation. Then have someone standing away, with someone else flipping the breaker.
Yep, dead short.
Old 07-13-2012, 11:04 AM   #6
Supposedly for resi. work you need level 2 arc flash gear.
And from your burn you can maybe tell how many watts/sq. cm. per second your skin got radiated with. Sunlight is 1 kw/sq. meter but it takes many minutes to get a sunburn.
Maybe the breaker didn't trip, in which case you got 3kA to 10kA or so through the arc.
Old 07-13-2012, 12:33 PM   #7
I highly doubt many residential panels have enough fault current to require any specific arc flash PPE. The hazard calcs rarely indicate a need for it in 120/240V panels, and when they do it's almost always a huge commercial service (800A+).
Old 07-13-2012, 12:46 PM   #8
But a Hazard/Risk Category 0 still requires PPE (long sleeves, long pants, safety glasses, hearing protection and gloves)
M Engineer is offline   Reply With Quote
Old 07-13-2012, 03:28 PM   #9
I never even knew about arc-flash until Mike Holt's forum talked about it.
An electrician long gone from this forum told me about level 2 gear for resi work.
Here's one that would have killed me:
a 17 year old was tree trimming, a branch fell onto a power line and enough current went through him to kill him.
I would have cut branches near power lines and my only worry would have been that the falling branch would break the line and PoCo would have come after me.
I guess I was assuming that tree sap is non-conductive except for lightning.
This kid is probably owed my thanks. He might have saved the life of my "future self".
Old 07-13-2012, 04:15 PM   #10
Of course. I meant "specific extra PPE for the elevated arc flash category".
Old 07-13-2012, 06:20 PM   #11
Master Electrician
we use the "space suit" all the time at my work. but we're also dealing with 1000A breakers. Being as we have the suit on site already we'll generally use it any time we're working on anything 100A and up.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 06:41 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Andrew, isn't the fact that you guys have guards around your main service lugs part of this safety practice? Im talking residential panels now...
Old 07-13-2012, 07:05 PM   #13
Master Electrician
i haven't had a new residential panel open in so long i forget what it looks like, the upper edge of the main has a guard in all the new panels i've done at work. you actually have to slide it out of the breaker to get at the lugs, basically unless you drop something into the hole from the top there's no way to hit the lugs on the main breaker.
and then you pop of the cover for the breakers and the busbar is exposed so go figure
Old 07-13-2012, 07:08 PM   #14
Master Electrician
heres a picture of a seimens tub at home depot here in canada, there is a gaurd at the top, nowhere near as well built as those used in commercial industrial applications but it's there nonetheless.
Old 07-13-2012, 07:27 PM   #15
MarginallyQualified
Rewards Points: 2,464
WHAT HAPPENED?
was this a new or old stove? who installed the cord?
had you seen this stove work before you plugged it in?
had you seen another stove work where you plugged in this one?
Wall Heater delay then Gas explosion. curtis19 HVAC 4 02-15-2012 09:39 PM
Gas explosion fireguy General DIY Discussions 3 09-21-2011 10:31 PM
load explosion when new furnace ignites Ken Sorenson HVAC 5 07-20-2011 08:34 PM
Price explosion!! Giles Automotive Repairs 5 02-03-2010 02:09 AM
Wiring an explosion proof fan jlaurent Electrical 15 10-26-2008 12:00 PM
