Experience Or Comment Regarding The GE 100-Amp Workshop Panel Kit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 05:02 AM   #1
Rewards Points: 1,016
Experience or comment regarding the GE 100-Amp Workshop Panel Kit?
Have been reading and posting about my detached workshop/garage. Getting ready to connect it up so looking for the bits and pieces needed to git-r-done.
Anyone have experience or comment regarding the GE 100-Amp Workshop Panel Kit available via Lowes for $54.00? Includes 100amp main breaker, a few 20amp breakers, 12 slots, and the ground kit.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=214802-76863-TM1210CCUG1K&lpage=none
I would be installing it in my detached garage, feed it from a 60amp breaker over three #6 wires with a #10 ground in about 100' of 1" conduit.
Old 05-25-2009, 08:49 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
That is a decent panel.
I install GE because that is what my supply house carries.
jbfan is online now   Reply With Quote
Old 05-25-2009, 10:19 AM   #3
Rewards Points: 168
Fairly good quality and excellent price. I have two GE's in my house and like them just fine.
$54.00 with main. You can't go wrong. 12 circuits on a 100 amp panel not so good.
Old 05-25-2009, 10:59 AM   #4
It's 12 slots and 24 circuits, so it says. I will only have maybe 1/2 the slots used, leaving room for forseeable expansion methinks. 24x30 garage/workshop for me working solo - so seldom multiple tools in use at the same time.
The 100 amp main breaker is a disconnect, panel fed with a 60 amp from the main panel.
1) 20 amp lighting
1) 20 amp general usage outlets - shop floor (table saw, chop saw, etc.)
1) 20 amp general usage outlets - workbench (bench grinder, drill press, etc.)
1) 20 amp small compressor outlet
1) 30 amp motorhome jack (only used for storage and occational maintenance / exercising the RV)
1) 220v 30 amp welder / plasma cutter
Old 05-25-2009, 11:15 AM   #5
Your plan sounds good and the price seems very good. I don't think you could buy that 100A main for $54
It depends entirely on what the circuits draw.
A dozen baseboard heaters...not so good.
12 circuits broken up for individual receps and lighting?.... great.
The fewer receps on a circuit, the less chance of overloading an individual circuit.
In a shop, I would install a dedicated circuit to each recep, just because. You'd spend 4 bucks on a breaker and a few more bucks on extra wire but you could then use any tool anywhere.
220/221 is offline   Reply With Quote
Old 05-25-2009, 11:59 AM   #6
I like that, would only add a couple more breakers for the general usage receps - as there are basically two wall areas with receps. The other two - built-in storage cabinets are along all of one 30' side wall, and a 16' double garage door in a 24' end wall. Thanks!
Old 05-25-2009, 03:14 PM   #7
Rewards Points: 79
You obviously haven't bought any GE major appliances lately, or you wouldn't even be considering buying a GE anything now. Go "Square D", and you'll get the nice "tripped" indication that most breakers don't have.
sootybuttercup is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Workshop Panel Grounding/Bonding IdahoBob Electrical 3 01-29-2007 11:13 PM
