Expansion Joints For Electrical Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 09:21 PM   #16
Electrician
Rewards Points: 802
You can actually get expansion joints for EMT as well, i have never had to use one though.
darren is offline   Reply With Quote
Old 04-17-2011, 09:32 PM   #17
Missouri Bound's Avatar
Although they are listed as required in the NEC book, the circumstances where they would be needed in any residential installation would be rare...if not non-existant. Only under extreme temperature changes and excessive lengths are they required, and not in burial situations.
The Following User Says Thank You to Missouri Bound For This Useful Post:
CDH (04-18-2011)
Old 04-19-2011, 03:16 AM   #18
Electrical Contractor
Its need is more common that you think. The code states an expansion joint “shall be provided” in straight runs between securely mounted items with an expected expansion of ”. A 20' straight run that’s mounted on the side of a house with a 40 degree temperature change would require an expansion joint.
hpp58 is offline   Reply With Quote
less than perfect looking expansion joints amakarevic Building & Construction 6 10-19-2010 11:13 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Not sure which forum, but Driveway Expansion Joints Leaking into Basement, help? ClemsonJeeper Concrete, Stone & Masonry 2 08-07-2009 11:42 AM
Concrete patio w/o expansion joints TrentJA Building & Construction 7 07-24-2009 03:28 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 05:44 AM
