Expanding Knob & Tube Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2008, 01:47 PM   #1
Rewards Points: 16
expanding knob & tube wiring
I'm remodeling my bathroom and there is a single switch operating a ceiling light. I would like to add a ceiling fan on an adjacent switch. Since it's knob & tube, their is only a hot wire going to the existing switch and then up to the ceiling light. From the light it travels back to the neutral line in the attic. Seems like I can add an additional switch by splicing (wire nut) into the hot wire before the original switch and connect it to the new switch (I'll install a dual swicth electrical box). Then I'll run a hot wire from the new switch to the fan and from the fan run a line to the existing light and splice into the existing line leaving the light (acting as the neutral). Is my logic correct??
jadrma is offline   Reply With Quote
Old 11-18-2008, 01:59 PM   #2
You cannot extend ungrounded circuits. Is the line with the neutral in the attic grounded?
rgsgww is offline   Reply With Quote
Old 11-18-2008, 02:44 PM   #3
Rewards Points: 16
Yes, the neutral runs in the attic are grounded at the 100amp Service Panel.
Old 11-18-2008, 02:52 PM   #4
joed's Avatar
Rewards Points: 12,926
Since all neutral wires are grounded at the panel let's ask that question in a different manner. Are there three wires including ground at the light fixture?
Old 11-18-2008, 03:18 PM   #5
Rewards Points: 16
No...this is knob and tube so there is only a single wire (hot) to the wall switch which then travels to the light fixture. That same wire then travels to the attic and ties into the parent neutral line which runs back to the grounded service panel. Only a single wire makes up the circuit.
Old 11-18-2008, 03:26 PM   #6
You have two options, install 14/2 with ground to the main (15 amp) or 12/2 with ground (20 amp) or not install the fixture at all.
If you decide to run wire you must read up your local code amendments...they may require certain methods (like conduit and type ac cable).
Old 11-18-2008, 05:01 PM   #7
Rewards Points: 16
Thanks for your help. I think I'll go ahead and get a bid on replacing the 100amp panel with 200amp and replacing all of the old knob & tube wiring.
Old 11-19-2008, 08:47 AM   #8
Rewards Points: 1,514
(While replacing all knob and tube wiring is recommended everywhere, in most places this is not mandatory even if you upgrade the panel. So you might choose to have a professional upgrade the panel while you replace wiring yourself at your convenience.
As you need new wiring work at the bathroom light switch, you might as well, if you do it yourself, rewire the bathroom light and decommission that part of the knob and tube wiring at the same time you install the fan. Instead of having both the new cable feed for the fan and the old K&T feed for the light entering the same switch box.)
Old 11-19-2008, 09:21 AM   #9
bradnailer's Avatar
I feel your pain. I renovated a 100 year old house with knob and tube wiring. The first thing I did was drop in a 200 amp panel then gradually rewired the entire house as I renovated rooms.
bradnailer is offline   Reply With Quote
Old 11-19-2008, 10:26 AM   #10
Rewards Points: 16
How do I change out my K&T wiring room by room? Is there a way to transition to 12-2 or 14-2 by splicing into the old wiring or do you have to make the change all the way back to the Service Panel thereby replacing the entire circuit and everything it operates?
Old 11-19-2008, 11:37 AM   #11
You would have to rip it all out and run new. I would recommend not doing it yourself if you do not know much about electrical (multiwire branch circuits, ampacity, etc.)
Old 11-19-2008, 04:05 PM   #12
You start re-doing each circuit by running the new cable from the breaker box. You may follow the route of the K&T hot wire from one receptacle to the next but you should add more receptacles if needed to meet code. (Typically 11 feet apart or so that a 6 foot cord from a lamp standing anywhere against the wall can run along the wall and reach a receptacle without crossing a doorway.) You may decide that two new circuits are needed to cover all the rooms that one circuit served years ago. If the K&T neutral goes back to the panel via another route, you do not need to continue running cable from the last receptacle that way.
There are special rules for circuiting kitchen, laundry and bathroom receptacles, including having separate circuits of 20 amps each.
Old 11-19-2008, 04:27 PM   #13
get 3 quotes from licenced electricians on replacing the panel and as many circuits that you can access without punching dozens of holes in the walls. i would also consider a 125 amp panel as it is cheaper than a 200 amp which you probably don't need anyway. we did this in our previous house and got rid of all but 2 W&K circuits.
mattedfred is offline   Reply With Quote
Knob and tube wiring PAULYBOY Electrical 1 03-28-2007 06:20 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
How safe is knob and tube wiring? jackdp Electrical 8 10-29-2005 10:50 AM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
