Old 10-22-2008, 06:41 PM   #1
Expanding foam for recessed lighting?
I'm installing some recessed lighting and I was woundering if I could better seal them with expanding foam from the attic side. They are IC or insulation contact remodel houseings by halo. Will this cause any problems? What can I do to seal them? Thanks JIM
http://www.homedepot.com/webapp/wcs/...3+90048+501111
integlikewhoa is offline   Reply With Quote
Old 10-22-2008, 11:04 PM   #2
My License Ain't 4 Sale..
I personally would not use the foam. You can get a gasket that fits the trim.
Old 10-22-2008, 11:47 PM   #3
Moderator
Termite's Avatar
x2
Old 10-23-2008, 12:38 AM   #4
Yea the gaskets I have seen, but there is alot of adjustment holes and other holes around the side of the can and its just not going to be sealed very well with only a gasket around the bottom of the ring.
Inside of the ring im sure I can put some silicone or calking around there and seal the can to the celing, but im more worried about air going around the bulb and threw the holes on metal can its self.
It would be nice to wrap or seal it better with something. I have a wide open attic above the celing with good access to it. Do you guys have any other options?
Old 10-23-2008, 02:08 AM   #5
The reality is that unless you have 500 cans, the amount of air that is leaking through is probably miniscule. I guess that if you just wanted to, you could silicone around the housing, but I would avoid the foam. What you also can do, is purchase the trims that allow for the socket to be clipped directly to the trim, instead of held by springs. I believe the can you linked will allow that. You just have to remove the metal plate that's held in by the wing nut. Where the socket attaches is another gasket. So, if you get those trims with a gasket on the bottom, then you should be pretty air tight without any adhesives.
Old 10-23-2008, 09:08 AM   #6
Moderator
Termite's Avatar
If it bothers you, consider building sheetrock boxes around the can lights. Foam's highly flammable, cans get mighty hot...Bad combination in my opinion.
Old 10-24-2008, 06:12 AM   #7
I agree the so-called airtight housings don't seem to be very air tight. If you put a light inside the can, it shines through the seams. According to the manufacturer, it actually needs to leak in order to keep from overheating (!?). Strange design...
For new construction, you can get plastic buckets that you put over the housing and seal to the ceiling drywall. The buckets are apparently large enough that the extra air volume allows for heat dissipation without leakage into the surrounding insulation. These don't work very well for retrofits, however - pretty difficult/impossible to get the bucket in placed and sealed properly.
I'm planning to seal the housing seams with metal tape, then put a bucket over the housing, but not try to seal the edges of the bucket, assuming that the extra air volume provided by the bucket would allow sufficient additional heat dissipation to prevent overheating.
Is this worth the effort? Opinions seem to vary. The spec for airtight housings is 2 cfm leakage at 75 Pa. That sounds like a lot, but I don't know what it amounts to in an actual installed fixture. The fact that they make these buckets seems to suggest that it's an issue.
pauln is offline   Reply With Quote
Old 10-24-2008, 03:13 PM   #8
The fact that they make these buckets seems to suggest that they want to sell it to you as an issue...
Old 10-24-2008, 03:29 PM   #9
Get a roll of that thin metal duct tape and cover all the holes in the can from the outside (except the installation clip sluts). Then, once installed, cover the clip slots from the inside..
The gaskets provided on the "air tite" cans are not very effective.
220/221 is offline   Reply With Quote
Old 10-24-2008, 05:36 PM   #10
Although expanding foam will likely work (it's self extinguishing and often used as a fireblocking material... I think other posters are referring to the XPS and EPS (eXtruded and Expanding polystyrene which is very flammable). I recommend putting flame to a piece of polyurethane expanding foam such as the stuff coming out of "Great Stuff" on fire, I've tried, the second you pull the flame away the fire goes out. They even make a fireblocking expanding polyurethane foam. Oh, that's when it's completely dry, until dry it is extremely flammable especially the fumes! Some construction workers working on a condo in the next town over were smoking while applying it, and burned the whole condo down!
There is a condition with polyurethane expanding foam that defeats its self extinguishing ability. That is, if you torch a hole into a block of it, you basically have made an oven that will cause it to burn. That is, the heat from the flame inside the hole will reflect to the foam and has no place to go it will be reflected back at the flame causing the flame to get more intense and reflect back to the foam and, rinse and repeat until there is an insane amount of heat and the foam will catch and stay on fire in that situation. It's not possible to have it catch on fire by applying a match or flame to the surface of it unless you keep the flame on it.
I recommend another route anyway. Air tight cans are pretty useless, but Home Depot sells Commercial Electric air tight inserts which look like a cone, they have a gasket at the top where the wires come in and around the base and those things are surprisingly almost if not completely air tight particularly combined with IC air tight fixtures. I use them everywhere I can. You can use Commercial Electric air tight baffles inside Halo IC cans. They are by the best way to minimize air leakage. Here's a picture.
Piedmont is offline   Reply With Quote
Old 10-26-2008, 06:17 AM   #11
Looks interesting. Do these fit inside cans made by other manufacturers? There doesn't seem to be much information about them on the web.
Thanks,
Paul N.
Old 10-26-2008, 06:20 AM   #12
They don't promote them - they make these because they are apparently required in new construction in Ontario.
Paul N.
Old 03-03-2009, 10:56 AM   #13
Piedmont, could you provide a link to the Commercial Electric baffle you posted about? I've looked on the Home Depot website and can't figure out which one I need. None of the photos look like what you posted and I can't figure it out by reading all the descriptions.
moyerles is offline   Reply With Quote
Old 03-03-2009, 11:04 AM   #14
Remodeling Contractor
Although expanding foam will likely work (it's self extinguishing and often used as a fire blocking material..
this is incorrect. Even Great Stuff makes a different foam for fire blocking. It is orange. Unfortunately many people do it wrong and even some propagate these ideas.
These holes are there for a reason. Do not directly block them. Foam boxes are made or make your own with drywall as suggested. Still need some room around for the lamps to breathe.
Old 03-04-2009, 08:08 AM   #15
The canned foams that are rated for fire are orange so that building inspectors can see them more clearly. Chemically they are the same as the normally sold products. I had a length discussion with one of the manufacturers about this. And, since they had to pay for government testing and certification of "a product", they make a special one dedicated for this market. But otherwise, the products are claimed to be the same.
However, since every manufacturer has these products, you may as well use the stuff that's "approved" so as to avoid problems down the line.
Dow's Great Stuff
DAP's comparable product
Handi-foam fireblock
NOTE: to clarify - NOT all foams are fireblocks! There are a variety of formulations, some burn, some don't. If you're tempted to use one that is not orange, fireblock rated, then at least try to set it afire under controlled conditions just to make sure the stuff you're using isn't the type that goes "poof!"
I also talked with the rep from Halo, one of the largest recessed light manufacturers, about various cans, air leakage, etc. an he said there's no problem with sealing up the fixtures if they're rated IC. The problem, he stated, was that people don't pay attention to the labels in the lights that show where you adjust the fixtures for various bulb styles and wattages. If you look closely, the larger the wattage, the more you have to adjust the bulb holder down, allowing it to dissipate more heat into the room. newer fixtures don't seem to have this adjustment, but have just a wattage limit.
Also, the other problem, he stated, was that you need to ensure your wiring is 90C rated. Older wire was 60C rated, and that presents a fire hazard that must be dealt with.
By the way, 2CFM at 75Pa is quite good. 75 Pascals is a high pressure. We do blower door tests of homes for leakage at 50 Pascals, and conventional fixtures leak a heck of a lot at that pressure. The key thing is to install them correctly. You have to caulk the perimeter of the fixture to the ceiling in order for it really to be close to air tight. Most installers skip this step and rely on the poor foam gasket to do the job, which it doesn't.
By the way, the same thing applies to your HVAC ceiling/wall/floor registers. Make sure the boot (the part attached to your duct and the ceiling) is caulked or foamed do the ceiling to make that connection air-tight. Otherwise, you're leaking a lot of warm moist air (in the winter) into the attic/walls/floor cavities where it leads to significant energy loss and possibly causes moisture problems.
tedsan is offline   Reply With Quote
Expanding foam insulation, where to find it in Nova Scotia? tankd0g Building & Construction 6 06-28-2010 05:33 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
expanding foam problem nev1 Painting 2 07-29-2006 10:21 AM
