Expanding To 4 Outlets Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 10:24 AM   #1
Expanding to 4 Outlets Question
Hello,
I am in the process of remodeling my den. I currently have a box with two outlets on the wall where my TV and other entertainment components would go. I want to expand the box to have four outlets in order to minimize the use of a power strip and cables on the floor. I am planning to do the wiring below. Can someone please let me know if you see any issues with this.
yellowrubiu is offline   Reply With Quote
Old 01-21-2010, 10:46 AM   #2
BIGRED
Rewards Points: 252
Looks good.
Grampa Bud is offline   Reply With Quote
Old 01-21-2010, 11:25 AM   #3
Licensed electrician
Rewards Points: 1,892
You could also tie the incoming and outgoing power together with 2 short pigtails of wire for each color. This would leave you with one pair of wires on each receptacle.
Old 01-21-2010, 12:04 PM   #4
Thank you for you feedback guys.
Jim - do you mean like this?
Old 01-21-2010, 12:07 PM   #5
joed's Avatar
Rewards Points: 13,754
Receptacles connections are fine. You don't need pigtails.
Old 01-21-2010, 12:56 PM   #6
Yes, that was the connection I was describing.
Old 01-21-2010, 01:52 PM   #7
300zx's Avatar
Post
Looks Good.If the black line is your hot you have it backwards.Hot is on the right(small slot on rec) and Neutral is on the left(big slot on rec) Like the first pic you posted (Old)
300zx is offline   Reply With Quote
Old 01-21-2010, 02:15 PM   #8
I'm going white wires to silver screws (silver circles in picture) and black/hot to brass (black circles) on the receptacle terminals. Thanks!
Old 01-21-2010, 04:10 PM   #9
Rewards Points: 1,548
Nitpicking the artistry.
When the receptacle is held with the silver screws on the right, the ground hole will be above the slots.
Old 01-21-2010, 04:36 PM   #10
Rewards Points: 1,016
Agreed - I find it easier to pig tail.
And I often double up on outlets like this where appropriate when installing new or remodeling - neater/better in that it does lessen the need for power strips and the like.
Replacing outlets: Pigtail, or don't pigtail? bassman99 Electrical 17 05-05-2009 02:50 PM
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 06:07 PM
Outlets on both sides of wall? and height question DIYGST Electrical 10 02-08-2009 06:11 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 01:13 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
