Existing Wiring (with Diagram Sketch) - Is It Ok To Leave Alone Or Should I Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 03:46 PM   #1
Military Mom of 4
Snav's Avatar
Existing wiring (with diagram sketch) - is it ok to leave alone or should I rewire
Sketching up the deal is easier than trying to get a good photo in the attic of the issue in question.
So I'm wiring for the bathroom and this is the present setup:
Now - before I dug through the insulation to see the wiring I was planing on leaving it all alone, reusing the existing wiring and just replacing the light-fixtures but now that I see what was done I'm not sure if I can.
I've tried to read up and determine how acceptable this is but there's no pinpoint answer to this.
So - ok to leave or do I need to redo?
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-31-2010, 03:54 PM   #2
Master Electrician
Rewards Points: 3,750
I would say it is fine unless you are replacing the fixtures with new ones that require 90 deg. C conductors and the existing conductors are not so rated.
brric is offline   Reply With Quote
Old 03-31-2010, 04:02 PM   #3
Military Mom of 4
Snav's Avatar
The old wiring is NM-B so I should be good then.
Old 03-31-2010, 04:04 PM   #4
Master Electrician
Yes, NM-B conductors are rated at 90 deg. C.
Old 03-31-2010, 04:55 PM   #5
Military Mom of 4
Snav's Avatar
Thank you, appreciate it - I was really not looking forward to having to rerun the wires
Old 03-31-2010, 05:53 PM   #6
Myself I replace any wiring without a ground
Old 03-31-2010, 06:11 PM   #7
Military Mom of 4
Snav's Avatar
A lot of my receptacles and so forth aren't grounded so I'm fishing ground wire through separately - I'll simply add it onto this in the same manor.
Old 03-31-2010, 10:35 PM   #8
Registered User
Rewards Points: 5,216
Don't forget the GFCI required in the bathroom........ ground or not. Whoops, ceiling lights, ah well - a good thought anyway.
Be safe, Gary
Old 03-31-2010, 10:38 PM   #9
Master Electrician
by far the best way to do it....so much stuff depends on the ground these days and far too many people just plop a three prong outlet on old wire.
then they wonder why they're electronic equipment suddenly stops working
andrew79 is offline   Reply With Quote
Old 04-01-2010, 01:47 PM   #10
Military Mom of 4
Snav's Avatar
Be safe, Gary
Got it covered.
You know all those bad experiences that people give keen advice in order to steer someone from ever going through it - well, I've been through all that.
Old 04-01-2010, 08:40 PM   #11
The Ontario Electrical Safety code allows ungrounded receptacles to be replaced with GFCI receptacles.
I assume that you are saying that the electronic equipment may fail if its surge protector doesn't have a grounded electrical supply! I'm unsure whether this is a fact or not, but my home, built in 1948 was wired with ungrounded Romex, and I have yet to have any of my electronics damaged due to this!
The intent of having grounded outlets was to ground the case of electrical appliances in case a short circuit occurred from the hot conductor to the case. It would then force the breaker to trip, thus protecting users!
Now we see double insulated devices, that do not require a ground for this purpose, so is it possible, that in the future grounded outlets will become obsolete?
Old 04-01-2010, 09:07 PM   #12
Master Electrician
not likely.....and some electronics stiplulate the there must be a ground connected for them to work properly. I actually had another post going in here where because of no ground electronic ballasts were inducing a voltage into the ceiling grid.
Part two of this is that in the event of a lightning strike the ground is what saves lives.
A third thing to mention would be what happens if your short happens in a wall or a box. That box is now live.
No the new code books are actually getting more strict on ground use rather than more lax. Grounds save lives.....period.
Old 04-05-2010, 12:21 PM   #13
Military Mom of 4
Snav's Avatar
Well - it wasn't fun but it's done. I found a few "eaten" parts of the existing wire (rats - old damage) while hanging my durrock so I rewired it all as a continual circuit rather than the mega-branch and just fed the new wire with ground in properly.
I didn't want to do it but now that it's done it wasn't *that* bad and only took a day.
Old 04-05-2010, 12:32 PM   #14
Learning by Doing
Leah Frances's Avatar
you get 100 awesomeness points for doing it right the first time
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Pot lights wiring diagram Eaglenest Electrical 5 03-29-2010 01:09 PM
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
Wiring Diagram Help Designman20 Electrical 3 10-22-2007 06:46 PM
wiring diagram potter67 Electrical 42 09-19-2007 01:30 PM
