Existing Switch For New Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 11:25 AM   #1
existing switch for new lights
I could use some help. I have an existing switch (power to switch) that is powering a light I plan on eliminating. I want to add two new lights to my garage and use the power from that switch for the lights. What is the best way to wire the lights from the switch? A diagram would be really helpful.
14/2 at the switch (black, bare copper, white).
eatonjr907 is offline   Reply With Quote
Old 04-23-2012, 12:07 PM   #2
joed's Avatar
Rewards Points: 12,858
Wire it the same as the old light. For the second light just go from the first light with another cable and match all the colours.
Old 04-23-2012, 12:09 PM   #3
Rewards Points: 2,516
This would be the way joed suggested above where power to the 2nd light is taken from the 1st light box
hammerlane is offline   Reply With Quote
Old 04-23-2012, 12:13 PM   #4
In this arrangement switching power for BOTH lights originate separately at the switch box location
Old 04-23-2012, 12:15 PM   #5
^only comment is 12/2 shouldn't be necessary, assuming this is a 15A branch circuit and voltage drop isn't an issue.
itsnotrequired is offline   Reply With Quote
Old 04-23-2012, 12:17 PM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Deleted
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-23-2012, 12:19 PM   #7
add an outlet while your at it
Old 04-23-2012, 12:25 PM   #8
^note that if that receptacle is going in the garage, it will need to be GFCI.
The Following User Says Thank You to itsnotrequired For This Useful Post:
hammerlane (04-23-2012)
Old 04-23-2012, 12:31 PM   #9
You're right good catch.
Old 04-23-2012, 12:32 PM   #10
still got the 12/2, i see...
Old 04-23-2012, 12:39 PM   #11
those labels were from when I posted this on another thread: remove the left switch and replace the ceiling fan symbols with light bulbs and you have the same drawing
Two Ceiling Fans, Two Switches, One Breaker
Old 04-23-2012, 12:43 PM   #12
So in this setup, would it matter if the power originates at the box itself? Can that "T" be farther away from the box, closer to the two lights? (Light one, "T" of wires, Light two)
Old 04-23-2012, 12:48 PM   #13
I do not understand your comment. Didnt you say in the first post:
I took this to mean you have incoming power which includes hot and neutral coming into the switch box.
The junction of wires could be in another junction box if thats what you mean.
The Following User Says Thank You to hammerlane For This Useful Post:
eatonjr907 (04-23-2012)
Old 04-23-2012, 12:57 PM   #14
Yes, I'm sorry, I realize that was not clear. In your diagram you have wires from both lights meeting at the box where the switch is and are combined there in a "T" then the one wire to the switch which has the power. So my question was can I have that junction of the three wires anywhere else with in the diagram instead of at the box where the switch is itself. It would be easier to have that junction in the crawl space above the garage closer to the lights.
Old 04-23-2012, 12:59 PM   #15
what about the diagram I added in post #13???
Just as a note I did not show any ground wires for ease of drawing and added the diagram again. You may be confusing what are wires and what are cables/romex
Double combination switch not turning on lights Mwright1978 Electrical 4 12-31-2011 06:37 PM
2 Wall Lights, 1 Switch twak21 Electrical 5 11-28-2011 06:59 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
2 lights one switch, power to the switch . . . gregoryc Electrical 15 03-17-2009 10:46 PM
