Old 11-29-2012, 04:50 PM   #1
Are existing outdoor receptacles on an older home grandfathered?
Hey all, Just wondering if someone may be able to help me with this?
I know that NEC states that any new construction outdoor receptacles must be GFCI protected, but what about older homes that were built prior to this requirement? If it's a grounded rec. with a waterproof cover, is this sufficient?
I know it's a good idea to upgrade them, but just curious as to where this would fall? Seems like a grey area.
Thanks, Jim
jimmerz is offline   Reply With Quote
Old 11-29-2012, 05:02 PM   #2
Lic Electrical Inspector
electures's Avatar
The NEC is not retroactive. The wiring has to meet what ever code was in affect at the time of installation. Local ammendments may supercede though.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 11-29-2012, 05:21 PM   #3
Code or not, it's a 10 min. job to change to a GFI and about $15.00 or less for the part.
Better safe then sorry, or dead.
electures (11-29-2012)
Old 11-29-2012, 06:08 PM   #4
If you want the features or advantages or protection of something new then you would not be asking the question of whether what used to be there is grandfathered.
Grandfathered means not complying with updated regulations but also not required to be upgraded or replaced yet.
Grounding (of the receptacle via equipment grounding conductor) protects equipment with or without a ground fault circuit interrupter. The GFCI protects people with or without the EGC in the wiring.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 11-29-2012, 06:23 PM   #5
Safety First.
bobelectric is online now   Reply With Quote
Framing and installing new patio door in older home MurphyMan Building & Construction 0 12-28-2011 07:56 PM
Replacing out of code ground wires in an older home Ozzie2341 Electrical 3 05-06-2011 12:59 PM
fireplace dimensions on older home...can it burn wood? JPinSD General Discussion 6 12-18-2010 09:40 AM
Install pre-hung door in older home DIY Hack Building & Construction 1 11-01-2010 09:03 PM
Rewiring older home Rt2frdm Off Topic 4 08-23-2010 12:35 PM
