Existing Basement Lights - Finishing Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 01:35 PM   #1
Hi All,
I'm finishing my basement and I have a 60A sub panel ready to go.
However the builder had already installed those cheap pull string lights at various places throughout my basement. Do I need to tie that circuit into my basement sub panel or can I just remove the light fixtures and terminate the wiring? Right now those lights are fed by my main circuit panel which is upstairs...
Any suggestions? What do most people do with existing basement light wires?
Thanks,
Jeff
bergsj is offline   Reply With Quote
Old 01-04-2013, 01:53 PM   #2
47_47's Avatar
Rewards Points: 50
The pull chain lights usually have power in and then continues to another box. You could remove the pull chain light, but the splice in the box must be accessible and not drywalled over.
47_47 is offline   Reply With Quote
Old 01-04-2013, 02:01 PM   #3
Would it be better to just remove all the pull chain lights and all the existing wiring? I plan on putting in recessed lighting throughout my basement..
Old 01-04-2013, 02:20 PM   #4
47_47's Avatar
Rewards Points: 50
Do you plan on drywalling the ceiling or using a drop in tile?
Old 01-04-2013, 02:29 PM   #5
I will drywall the ceiling...
Old 01-04-2013, 02:35 PM   #6
47_47's Avatar
Rewards Points: 50
If you could find both ends of the wires, re-run without a splice and eliminate the old light box entirely. That can be a lot of work. Why can't the lights stay on the existing circuits?
Old 01-04-2013, 02:38 PM   #7
I suppose my new recessed lights could stay on the existing main panel circuits, I would just like all my basement power to be running from the basement sub panel.
Finishing my basement... the1german Project Showcase 2 06-09-2012 11:37 PM
Recessed lights in basement Carl Ealy Electrical 12 04-14-2012 10:13 AM
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 10:19 AM
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 09:27 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
