Exhaust/light Unit- Exhuast Stays On Even When The Switch Is Off. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 09:08 PM   #1
Exhaust/light Unit- Exhuast stays on even when the switch is off.
I am replacing the light box in the bathroom with a exhaust/light unit.
When I hook up the unit, the exhaust runs continuously even when the switch is off. The light seems to be working fine, It turns off when I turn off the switch.
I have 3 lines coming into the Junction box.
Line 1: Has 1 black and 1 White wire
Line 2: Has 1 black and 1 white wire
Line 3: Has 1 black, 1 white and 1 Red.
Not sure if the color of the lines mean anything but Line 1 and 2 are white. Line 3 is black.
All the 3 black wires are tied together and all the 3 white wires are tied together.
The fixture has 1 blue, 1 black and 2 white wire.
I am connecting the blue to the red. The 1 back wire from the fixture is connected to the 3 back wires in the junction box. The two white wires from the fixture are connected to the 3 white wires in the junction box.
What am I doing wrong?
pdamania is offline   Reply With Quote
Old 06-04-2012, 10:06 PM   #2
kevinp22's Avatar
Rewards Points: 252
there is only one switch, correct?
if so, take that black fixture wire out of the black pigtail and tie it to the red wire.
the blue wire is the light which is connected to the red switched wire
the black must be the fan and by connecting to those other blacks its wired as always hot
kevinp22 is offline   Reply With Quote
Old 06-05-2012, 02:46 PM   #3
If I understand this correctly, there will be 3 pigtails:
Pigtail 1 1 Black wire from the switch and 1 Red wire
Pigtail 2 2 hot black wires
Pigtail 3 3 white wires
The blue wire from the unit would be tied to Pigtail 1. The back wire from the unit will be tied to Pigtail 2. The two white wires from the unit will be tied to Pigtail 3.
Is that correct?
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Illuminated switch ??? dave95sps Electrical 5 05-29-2011 05:11 PM
Pressure Switch Problem? American Standard Pack Unit jaymel HVAC 4 10-20-2008 05:10 AM
