Exhaust/light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 11:37 PM   #1
exhaust/light fixture
can i use the existing wires from old light to run new fan/light?
jasber666 is offline   Reply With Quote
Old 11-16-2012, 11:42 PM   #2
anyone have advice for me?
Old 11-16-2012, 11:52 PM   #3
Rewards Points: 6,652
Depends on what the wiring is, and what the fixture is rated at.
Old 11-16-2012, 11:54 PM   #4
Rewards Points: 14,312
If the wires are in good shape and you want the light and fan to always run at the same time then there's no reason to not use them.
Old 11-17-2012, 12:11 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Yeah you can but it depending on how it set up so like if you have only single NM cable then it will be no issue but if you have two cables it can affect the set up.
Make sure that you understand the switch loop is differnt so before you start take apart look at your switch to see how it conferated first that useally can save yourself alot of headache.
Second thing be aware the junction box in the fan / light combo unit there is not a really much room at all so you may have to make a junction box next to it ( if you have attic that is not a issue but have no attic in this area let me know I know there is other way you can do.)
Merci,
Marc
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 11:19 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
