Exhaust Fan Wiring In Old Home - Electrical - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 11:03 AM   #1
exhaust fan wiring in old home
How do I wire a new bath exhaust fan to an old switch that only has a single black wire cnnected to bottom of switch and a single black wire going out
jgc123 is offline   Reply With Quote
Old 09-06-2011, 11:04 AM   #2
Just call me Andrew
Rewards Points: 1,020
Do you already have a fan in place that you are replacing? You need to provide more details, give the whole picture.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
jgc123 (09-06-2011)
Old 09-06-2011, 11:13 AM   #3
Exhaust fan wiring in old home
No I want to install a new fan
Old 09-06-2011, 11:15 AM   #4
Just call me Andrew
What did this switch used to control? You are going to have to run a cable from the switch location to the fan.
Andrew
Old 09-06-2011, 11:21 AM   #5
The switch is to light in bathroom
Old 09-06-2011, 11:27 AM   #6
Just call me Andrew
It's very hard to help when you don't give all the details from the start.
Please provide the entire picture as to what you are trying to change.
Andrew
jgc123 (09-06-2011)
Old 09-06-2011, 11:34 AM   #7
Licensed electrician
Rewards Points: 1,256
Are there any white wires in the switch box not attached to the switch?
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
jgc123 (09-06-2011), secutanudu (09-06-2011)
Old 09-06-2011, 12:26 PM   #8
Exhaust fan wiring in old house
The existing switch is to light above medicine cabinet. It has no white wires only 1 black wire to bottom and top of switch. I ran a 14-2 w/ground from fan to switch box. how do i connect them
Old 09-06-2011, 12:29 PM   #9
Without a neutral in the switch box you will not be able to have all the wires you need for the circuit.
Old 09-06-2011, 06:46 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,102
Without a neutral connection at the switch,
you can not run all the wires from there,
But if the fan is not to far away from the light,
then you might be able to run the wires from there,
As there will be a neutral at the light.
dmxtothemax is offline   Reply With Quote
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 07:07 PM
Simplified Bathroom Exhaust Wiring Problems eddytheflow Electrical 2 08-13-2011 04:43 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
wiring a bathroom exhaust fan Tool Junkie Electrical 8 09-27-2007 03:53 PM
