Exhaust Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 11:22 PM   #1
exhaust fan wiring
I am after a wiring diagram for a Mistral 6108-0 exhaust fan. Im in a new house and the fan has never worked. I dissembled it to find no power connected - there are 3 unused terminals on it. There is a power and earth lead seemingly there for the purpose but is not connected. Which wire goes to which terminal? thks Lindsay
Linds1 is offline   Reply With Quote
Old 11-28-2010, 01:22 AM   #2
Rewards Points: 150
Mrrh.
The terminals have to be labeled somehow. I notice you didn't bother to tell us the labeling. I suppose you think I'm gonna spend the next ten minutes looking up the manual?
Ain't gonna happen. Here's a brief summary. You figure it out, or give us some useful information. Your choice.
One terminal is hot. It will be labeled HOT, LIVE, LINE, L1, L, or H, or have a BLACK or RED wire attached to it. This connects to the hot/black/red wire from the wall.
Another terminal is neutral. It will be labeled NEUTRAL, NEUT, or N, or have a WHITE wire attached to it. This connects to the neutral/white wire from the wall.
The third terminal should be ground. It will be labeled GROUND, GRND, GND, or E, or have a ground symbol (a triangle made up of 3 horizontal lines with one vertical line above them). It connects to the ground/bare/green wire from the wall, if'n there is one.
emolatur is offline   Reply With Quote
Old 11-28-2010, 08:36 PM   #3
Rewards Points: 1,580
Likely you are in Oz? If so, someone familiar with that electrical system should chime in. Most responses here based on US/Canada system.
bob22 is offline   Reply With Quote
Old 11-28-2010, 11:08 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Bob 22.,
Yes the OP is from OZ area and I will fill in the requirement.,
OK for your fan the bleu is netural while the brown is active unless you have older conductor colour code then Black is netural while red is active { Live } and on your unit you should see marking A and N and E.
Do you have a wall switch near the fan unit ?? if so you may want to take a look to see if that hooked up as well.
Merci.
Marc
Wiring a ceiling mounted exhaust fan in a bathroom Gibbo Electrical 8 09-11-2010 12:01 PM
Need wiring help with a bathroom exhaust fan Brieninsac Electrical 3 04-16-2010 12:06 PM
Wiring Replacement Bathroom Exhaust fan wkend3 Electrical 3 10-22-2009 11:07 AM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 04:15 PM
exhaust fan wiring question (aluminum wire) sflamedic Electrical 6 01-14-2008 04:41 PM
