Exhaust Fan Nightmare - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2009, 02:22 PM   #1
Rewards Points: 22
Hi. I wanted to replace a timer that works my bathroom exhaust fan. The one in there is the wind up type that makes noise until it clicks off. I decided to spring and get the push button professional looking type. When I hook it up the fan immediately turns on and I can't turn it off. It's not the switch as I got a replacement one and it does the same thing. The box has a black and white coming in. I tested to see which one has the load and it's the white one. Can anyone help get this thing going? Thanks in advance. Paul
pgs_28 is offline   Reply With Quote
Old 10-24-2009, 02:33 PM   #2
joed's Avatar
Rewards Points: 13,762
That timer switch requires a neutral I think. You do not have a neutral, even though you have a white wire. Put back the spring wound type. It doesn't need a neutral.
Old 10-24-2009, 02:36 PM   #3
Rewards Points: 22
How do I get a neutral??? I really want to install this new switch
I have a switch right beside this one in the same box that controls the light over the vanity. Anyway I could us power from that or something? thanks Paul
Old 10-24-2009, 02:40 PM   #4
joed's Avatar
You can not use power from the other switch. You need a neutral. A neutral will be a white wire that is not connected to a switch. Tell us all the wires in the switch box.
Old 10-24-2009, 02:47 PM   #5
Rewards Points: 22
Here ya go...
I have 2 wires coming into the 2 gang box. one of them is hooked up to the light and the other to the fan. I also have a outlet about 6 inches away.
Old 10-24-2009, 03:09 PM   #6
joed's Avatar
Do you mean 2 cables and 4 wires + grounds? If the four wires are all hooked to the switches then you have two switch loops. You can't do it. No neutral wire. Find a timer that doesn't use a neutral.
Old 10-24-2009, 03:16 PM   #7
Rewards Points: 22
yes 2 cables, 4 wires.... + 2 grounds. ARGH....... Can I run new wire or something. Wait... do they make a silent timer or a timer that doesn't need a neutral but is motion sensitive? Btw ...thanks for all your help.
Old 10-24-2009, 03:24 PM   #8
Rewards Points: 22
Just re-read your post. I have 1 cable coming in one side and hooked up to the switch for the vanity light. Another cable comes in the other box and controls the exhaust fan.
Old 10-24-2009, 04:28 PM   #9
Electrical Contractor
kbsparky's Avatar
How many wires are on the new timer? What colors are they? Do you have a brand name and model number?
Care to post a picture of your switch box, with the switches hanging out, but still connected to the wires?
-KB
Old 10-24-2009, 08:01 PM   #10
You could....but you don't want to open that can-o-worms.
Find a timer that doesn't require a neutral.
220/221 is offline   Reply With Quote
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
