Exhaust Fan Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 12:45 PM   #1
exhaust fan circuit
Thinking of installing an exhaust fan in bath. Does that require a dedicated 20 amp circuit?
Joe Tilghman is offline   Reply With Quote
Old 12-17-2012, 01:04 PM   #2
TTW
TTW's Avatar
Not unless you get one big enough to suck all of the air out of your house in 45 seconds flat!
But seriously, by NEC, lights, fan, and receptacles can be on one circuit if it is a 20 amp circuit that ONLY serves that one bathroom and nothing else.
Otherwise, I believe you could tie into an existing general lighting circuit.
Bathrooms CAN share 1, 20 amp circuit, IF the ONLY thing that circuit powers is the receptacles in the bathrooms. Seems weird to me, but that's the code.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-17-2012, 01:11 PM   #3
Thanks for the reply
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
bathroom exhaust fan, need separate circuit? beech Electrical 6 04-15-2011 06:00 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
