Excessive Voltage - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 01:08 PM   #31
Mad Scientist
Don't forget that a digital multimeter with low batteries typically reads higher than actual voltage... Just throwing that out there as something to check.
McSteve is offline   Reply With Quote
Old 08-03-2013, 01:36 PM   #32
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,436
Sir Sparky..... Agreee..... Are we sure that is correct analysis for a MWBC thats gone in SERIES with a lost neutral....
Very well may be exactly correct....... not saying it isn't... just still thinking if series has affected anything.
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 08-03-2013, 01:38 PM   #33
Steve THANKS.... never knew that.....any idea how much a low battery can effect V reading..... several volts?....10%
Best
Old 08-03-2013, 02:00 PM   #34
Mad Scientist
Best
I've seen mine read anywhere from 140 to 180 on a 120V circuit when the battery is low. Thought I'd mention it since the OP was saying his voltage readings where adding up to more than 240.
The Following User Says Thank You to McSteve For This Useful Post:
MTN REMODEL LLC (08-03-2013)
Old 08-03-2013, 10:53 PM   #35
" Euro " electrician
frenchelectrican's Avatar
Amazing you and I haven't electricuted ourselves yet..... however, we do know what we don't know.... and are willing to learn
I know you guys are lucky so far but just go on the ride with us and you will learn alot more than that.
But I got electrique shock few time over the years some were not and some were pretty nasty and I got it thru the nasty part allready many years ago and I do know what voltage that one I got hit pretty hard ( Tabarnac !!!* )
Now let get back on the main point did Sirsparkalot do understand this part ?
And I am waiting to see to follow up what he done with this funky circuit yet.
Merci,
Marc
* A French cussing word ( Quebec verison )
The Following User Says Thank You to frenchelectrican For This Useful Post:
MTN REMODEL LLC (08-04-2013)
Old 08-03-2013, 11:31 PM   #36
JOATMON
ddawg16's Avatar
Rewards Points: 840
Not my Fluke or HP....but I could see the cheaper ones doing that.
FYI....on a more serious note.....nothing wrong with checking the 'calibration' of your meter now and then.
Obviously, resistance is easy...
For DC....check the voltage of a fresh 9 V battery
For AC....check a known good service...
The Following User Says Thank You to ddawg16 For This Useful Post:
Kyle_in_rure (08-03-2013)
Old 08-03-2013, 11:44 PM   #37
Rewards Points: 506
Howdy Marc. Well POCO came out and found nothing wrong on their side.
We did find 242V on Bathroom GFCI, however. So finding the open neutral in the attic is the next step. I'm quite curious about this, for the following reason/
I can't seem to get a steady voltage on this. The voltage presence is intermittent. When I first got there today, I found no voltage at all after POCO had checked and said there was 242V on the receptacle. Then, I went and shut the breakers off, then turned them back on, then shut one at a time off, and then on, and then both back on again, checking for voltage each time. Finally, I got the reading: 213v on the GFCI. It's weird that the voltage is intermittent like that.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
frenchelectrican (08-04-2013)
Old 08-04-2013, 07:52 AM   #38
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It could be intermittent because the neutral is loose, or failing... im guessing a not so good connection and is burning up somewhere.... i.e, backstabbed receptacle, poor splice, etc....
Old 08-04-2013, 11:52 PM   #39
I figured that you read Stickboy's comment on this one and I am the same page you have intterment loose connection somewhere along that circuit so check each one as you work it way out from panel.
I think you may hit a intermment cross connection which it can spike the voltage up 242 volts ( if that is true your GFCI will smoked out so smell if burnted allready .)
Bon Chance.
Merci,
Marc
Old 08-05-2013, 11:58 PM   #40
Rewards Points: 506
Originally Posted by stickboy1375 View Post
A open/bad neutral conductor on a MWBC has no effect on the main service.
Found the culprit, untwisted and loose neutrals at the kitchen light (first hit from the panel). Also replaced four single pole breakers with 2 doubles.
Stick, I don't know, but after correcting the loose neutral, all voltage went back to normal.
Thanks to everyone for their comments and help.
Old 08-06-2013, 12:06 AM   #41
Sir Sparky.....
Do you figure your 135V reading at your main service was maybe just a bad DVM reading?????
Best
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
sirsparksalot (08-06-2013)
Old 08-06-2013, 12:11 AM   #42
Rewards Points: 506
Sir Sparky.....
Best
Well, I guess that's possible. I now recall that I did replace the 9V before rechecking.
MTN REMODEL LLC (08-06-2013)
Old 08-06-2013, 12:21 AM   #43
Electrical Enthusiast
Rewards Points: 504
Glad you figured it out
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Old 08-06-2013, 12:48 AM   #44
JOATMON
ddawg16's Avatar
Rewards Points: 840
I just love a happy ending to a story.....and thanks for the update....
Beer for everyone.....sirsprak is buying....
Old 08-06-2013, 12:58 AM   #45
What kind of beer ??
Merci,
Marc
Low voltage interior wiring systems WillK Electrical 0 01-03-2011 09:14 PM
Phantom voltage -- I'm completely stumped kb01 Electrical 2 12-24-2010 07:44 PM
190 185 voltage ? PIGEONS Electrical 10 12-21-2010 12:45 PM
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
