Every Other Switch In Main Panel Is Fried - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 01:01 PM   #16
Rewards Points: 3,256
Originally Posted by crescere View Post
Also, I have used my digital meter to tet outlets, but can I put it on the main cables coming into the ciricuit breaker? Is it red meter wire to the cable and the black meter wire to the neutral bus? Will I fry my meter? can I get shocked?
From everything you have said I don't think you need to check any further. If you want to continue, read joecaption's post and also make sure the meter leads are in the correct holes for voltage, not current. That will light things up real good, in a bad way.
zappa is offline   Reply With Quote
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 12:58 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
