Event Power Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2013, 12:29 AM   #1
REP4507's Avatar
Question
Event Power Box
I need some help understanding how to design a three-phase power box.
The end result is 12 x 10A GPO's (3 quad 10A points), 4 x 15A GPO's (2 double 15A points) and a single 20A GPO. All switched.
I want the box to have a master kill switch from input that will lead into a master RCD.
Then each set of GPO's will have its own ganged breaker and then a MCB for each outlet itself, with an RCBO on the 20A because Im paranoid.
End result should look like the image provided (image is to scale).
This will be a wall board. The 20A will run a jumping castle the 10As are for miscellaneous items and the 15A will be for fridges and coffee grinder/machines.
I have a 415V 5 pin IP 67 ceeform for a power source.
REP4507 is offline   Reply With Quote
Old 11-18-2013, 05:52 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
My only advice to you is to have a professional build this for you. It's for a business so why cheap out and attempt to do it yourself?
Also, it would help if you put your location in the post or your profile. Most of us here are in the US or Canada, and it is obvious that you are not. You'll likely need someone familiar with your country to even get building advice.
Speedy Petey is online now   Reply With Quote
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (11-18-2013), mpoulton (11-19-2013)
Old 11-18-2013, 04:52 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,372
Sounds like he's in Australia ?
As I am here in Australia I can help !
But I also know that the Australian authorities are SUPER strict with
electrical regulations in reguards to carnival type rides and stalls.
In fact they are given the highest level for safety requirements.
And are you sure you want a main RCD ?
all you need is one small leak,
and it will take out everything,
Not so smart if you are running lights as well.
Better to use individual rcd's on each outlet,
So you dont suddenly plunge everyone into darkness.
Messing with three phase at 415v is extremily dangerous
and Not recommendded for ametures.
But if you must we can help !
dmxtothemax is offline   Reply With Quote
The Following 4 Users Say Thank You to dmxtothemax For This Useful Post:
gregzoll (11-18-2013), mpoulton (11-19-2013), REP4507 (11-20-2013), Speedy Petey (11-18-2013)
Old 11-20-2013, 02:54 AM   #4
REP4507's Avatar
Yep Aussie.
This is for a not-for-profit organization and not for huge carnivals just tiny local fairs we host onsite for fundraising.
We have a contracted group of sparky's that charge for design time. That's about $45 per half hour. So if we provide them with a well worked out base idea and they OK it, we use another contracted wholesale dealer to purchase all the required components and parts needed. We cannot go outside of our contracts as there is more than one facility linked to them.
On one hand it pisses off the sparky's as it only allows them to charge labour, but on the other we save lots. For example, what was quoted as five sets of $4000-$5000 system additions or upgrades, have been reduced to $2500 each and we got a bulk discount on the labour from $98 per hour down to $77.
Every part in our facility is the same class/type, has been documented, checked and its warrantying noted in case it fails.
That being said I am/was a technical trade assistant before I took up my current post. It generally falls to me with these things as I have some idea how they work. However I have very little experience with three-phase power.
Regarding the RCD I suppose it would be possible to switch all the MCB's (main circuit [overload] breakers) with RCBO's ([residual + overload] breakers). However how will that work with the three-phase. Will it not need to enter and disperse after exiting from the main KILL breakers? Would it not still be best to go through a modulated three-phase RCD before the RCBO's?
Old 11-20-2013, 04:32 PM   #5
If maximum safety is your main concern,
Then yes use a three phase RCD,
How ever I think the risk of plunging everyone into sudden darkness
is also just as dangerous.
Using individual rcd's is a better option
provided there are no three phase loads.
You should check with the Electrical Safety Office
with reguards to your classification
You could still be classified as carnival type rides
And there where changes recently
You can access them online, thru the dept of justice website.
I understand that you want to save money,
But the government is super strict now days with electrical safey
And all it takes is one problem where someone is hurt,
And it will cost you ten times what you could have saved.
The old excuss that we are just trying to raise money,
doesn't wash anymore in a court of law.
YOU MUST PROVIDE A SAFE ENVIROMENT.
Old 11-20-2013, 11:12 PM   #6
What is your next question ?
You dont need joined breakers if there single phase loads,
Again if one tripps all go out.
Since there are no three phase loads,
you dont need joined breakers.
Old 11-26-2013, 07:00 PM   #7
REP4507's Avatar
Exclamation
New design.
No, I want to use a three-phase power source, convert to single phase and power the GPO's.
Regarding the original suggested design. They are not joined trip breakers I'm suggesting. But BREAKER's [Main Switch Cut] Breakers or simply Joined On/Off switches.
Bit if I am having individual RCBO's for each GPO then I will just use lockout keys instead.
I had wanted to just switch off and lock off a set of GPO's. Thus preventing anyone for firing up a line I don't want them to touch. Since the box would only be used in combinations of 15's only 10's + 20. etc.
See new designs below.
Old 11-26-2013, 10:10 PM   #8
Why is number 6, A 20A outlet, but a 32A breaker ?
Otherwise it looks ok so far !
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 08:00 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
